Question about Verizon Communications Samsung Gleam Cell Phone - Black
Bell icon crossed off and phone wont eing. Setting changes don't help
Phone will not ring bell is crossed of how do i turn it on
Can you please tell me what's the model of your Bell phone? -Thanks
Aug 22, 2015 | Bell Lands Phones
Bell complaints
please go to setting and select defolult setting and slove the prolbme
May 24, 2014 | Computers & Internet
I have a corded model #77519 phone, how do I change the time and date.
The complete user's manual for your phone is available at the following link:
http://www.retrevo.com/d/df/MANUAL000032975.pdf?doc=532906c5a747ab87134404141e9c11c8&ts=1313184836863&rk=0.17208479428095913
Just use your mouse to click on the link which is the highlighted and underlined text above. This will open a new browser page for you automatically and allow you to download the manual.
Here is an excerp from that manual which describes how to set the time and date:
GETTING STARTED
Caller ID Initial Setup:
After the battery installation and telephone line connection the display will show the Set Language screen:
Set Language
1. Press the Review UP or DOWN button to select the desired language.
E=ENGLISH
F=FRENCH
S=SPANISH
2. Once the desired language is selected , press the ERASE button to
confirm selection.
3. Then the display will change to the Set Time / Date screen and the hour icon will be blinking.
Set Time/Date
1. Press the UP or DOWN button to set the current hour.
2. Press the ERASE button to shift to the minute setting.
3. Repeat steps 1 and 2 above to set MINUTE, MONTH and DATE.
4. Once the correct TIME/DATE is shown on the display, press the
ERASE button to end the setting. Then the display will change to
show the normal status.
Changing The Language Mode and TIME/DATE
1. Press and hold the ERASE button then press UP button.
2. Then follow the steps described above.
Good luck, I hope this was helpful.
Joe.
Aug 12, 2011 | Northwestern Bell 77519 Corded Phone...
I have my new samsung corby 2 gt-s3850. there's an "e" icon or the edge network appeared on my fon.. does it mean that im still connected to internet? i'm worried because i don't know...
No your phone is not connected. The 'e' means that your phone is internet connection on it, that is you can use your phone to browse on internet. So , do not worry yourself.
To get the phone profile, scroll to phone setting, press okay and scroll to phone profile. Regards.
Jun 19, 2011 | Cell Phones
Cant seem to make the icons smaller on display packard bell easynote tj65
If you are using Vista/Windows 7 Right click anywhere on your display and you should get an option under view to change the size of your icons or you could change the display ratio/screen resolution which will automatically adjust icon size the higher the display setting the smaller the icon.
Jan 11, 2010 | Computers & Internet
No ring on incoming call
i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Nov 08, 2008 | Samsung SGH-D900 Cellular Phone
Offline
try open ur handset and make the pcb warm with ur hairdryer and fix it again i think it is due 2 moisture and it should work as its not picking simcard.try it and reply me with results.
Jul 12, 2008 | Nokia 6630 Cellular Phone
Icon description
that is the GPS indicator, which shows that your phone is GPS compatible (which is now a feature that is required by the FCC). if you look in the menu under "settings" i believe that there is a "location" setting which would allow you to select "location" or "911 only".
Feb 13, 2008 | Motorola Mobility E815
Verizon Communications Samsung Gleam Cell Phone - Black Logo
76 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
