I have a Franzen 3 dial lock on my briefcase. I haven't used for a long time. How do I reset the numbers? I can not remember the combo numbers I used.
I have a briefcase I want to unlock it.
Steal a different briefcase. Otherwise, especially since you did n't specify the brand or type of briefcase, you'll need to break the locks to get into it.
May 11, 2015 | Briefcase Luggage & Travel
Set combination lock
Step 1:
Locate the reset button, usually placed to the side of the combination dials.
Step 2:
Press the reset button and hold it while rotating the number dials to the desired combination.
Step 3:
Release the reset button after you set the numbers to the new combination.
Try that :)
Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
Is there an owner's manual available on line for a Stebco Attache Case Model P-16? I need to know how to set the combinations on the dial lock system.
I couldn't find the manual for your particular briefcase, but please read the instructions on the attached link. It should help you since most briefcase combination locks work the same. Hope it helps.
How to Change the Lock Combination on Briefcase
Oct 27, 2014 | Lands Phones
Have old 50 yrs weilink safe have comb. not opening
You could have the correct combo... but not be using the correct pattern. Here it is.
Turn dial several times to the right to clear it...stop on 0
Turn dial to left (ccw) 3 times past the first number and then stiop on that number the 4th time around.
Turn dial to right 2 times past the second number stop on that number the 5rd time around
Turn dial to left 1 time past the 3rd number and stop on the 2nd time around.
Turn dial to the right until it latches (could be the last number or the drifted number) until it stops
Twist handle and open door.
NOTE:If this fails to open it then its possible (after years of use and w/o service) that the numbers 'drift' from there original spot. You can try to find this out by applying pressure to the handle (which engages the 'fence' inside and rubs it against the wheel pack). While applying light pressure rotate the combo dial and where it locks up should be one of the numbers... check this against your 'correct combo' and see how they match. If it's off then all of them are off. You'll need to determine the 'new' combo by drawing the dial with the numbers use the fence located number (usually the first or last) and then reverse engineer the combination. You may also want to grab a book on safes/ safe-cracking to understand the mechanics if this doesn't make sense. Good luck!
Jun 03, 2014 | Safe International Digital Electronic Safe...
I have a black dog TSA lock and can't remember the combination help
if you have forgotten the combo the only way to figure it out is to progress the combo starting from 000 and then 001,002,003,004 etc...( trying the lock at every new series until you get the correct combo. a 3 digit combo should only take about 10 to 20 minutes to solve. you can cut the time in half if you can remember the first number or the last number.
chris...
Sep 13, 2012 | Ultra Hardware Black Dog 55164 3 Digit...
I need to reset my combination on a pilot leather case
This is how you generally change the combo on a briefcase
1. With the briefcase closed put int the combination
2. Slide the bottons in the opposite direction than you usally do to open it.
3. Now set your new password.
4. Slide the buttons back into place.
5. If it dosent work the first time try it a few times
6. If it fails try reposting with more specific model information about your briefcase
Jun 28, 2011 | Office Equipment & Supplies
How do you set your own combination for the locks on the briefcase,there were no instructions with the case
  • 1 Turn the lock to the correct combination and open the briefcase.
  • 2 Look at the lock. There should be one or two pins that you can slide with your fingers. If there is one, simply push it in. If there are two, push them together. It may be the same button you use to open the case.
  • 3 Change the lock to an easy-to-remember value, such as 000 or 123, to test the lock. Release the pin.
  • 4 Close the briefcase and turn the lock to another value. It should not open. Now turn it to the test combination. It should open right up.
  • 5 Repeat Steps 2 and 3, but this time choose a number that will be easy for you to remember, but hard for someone else to guess. Write down your new combination and keep it somewhere safe.
  • Dec 29, 2010 | Office Equipment & Supplies
    Get the numbers master dial combination lock
    Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
    Please rate. Thanks
    Feb 21, 2009 | Hardware & Accessories
    Brinks safe
    As I understand that safe has four numbers to the combo. 1) turn the dial to the right passing the first number 4 times stopping at that number the next time around. 2) Turn the dial to the left passing the second number 2 times and stopping on that number the next time around. 3)turn the dial to the right passing the third number 1 time and stop on that number the next time around. 4) Turn the dial to the left stopping on the last number. 5) Insert the key into the cylindrical lock and turn it to the right.
    Sep 03, 2008 | Check Point Network Adapter
    898 people viewed this question
    jasbo
    jasbo
