Question about Kodak EasyShare Z740 Digital Camera
When I turn my Z740 on to take pictures, it automatically goes to review pictures. Even with new batteries or plugged into ac adapter.
  • jimboarcher3 Sep 10, 2010
    It won't let me override it at all. Unless you know a way to manually override it but it just makes me review the pics
    President:
  • 2,185 Answers
Check for the Mode Dial and make the necessary adjustments and choose LCD or EFV (electronic viewfinder).
Posted on Sep 10, 2010
  • 3,083 Answers
This sounds like the review button is jammed or broken. It will have to be disassembled to ascertain if this is so, and to fix it. If you can select to take pictures and override it, it will be cheaper to live with it than have it fixed.
Hope this helps, and good luck.
I have an Acer G246HL. When I turn it on the power saver symbol comes on, then the screen goes blank. (ie no picture)
I would suspect the battery is failing in this, even with the AC wall plug adapter connected the unit's battery must be good to function correctly, the AC wall charger is designed to charge the battery not power the entire PC laptop.
Nov 04, 2016 | Acer Computers & Internet
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Troubleshoot no power supply even the charger is connected
What to Do if Your Laptop Is Plugged In but Not Charging ...
www.pcmag.com > Reviews > Laptops & Notebooks
PC MagazineAnd no battery charging. ... but some problems may require a visit to a repair shop oreven a full-blown ... Get ready, boys and girls, it's time to go troubleshooting. ...Check the AC adapter brick and verify that any removable cords are fully ...
Laptop Won't Power On - Troubleshooting a AC/DC Adapter ...
www.ifitjams.com/lappower.htm
Troubleshooting problems where the laptop won't power, adapter LED is off ... When your laptop won't turn on with the AC power adapter plugged in, many ... SOme laptops even feature a power button that lights when the power is turned on.
Sony VAIO® - Some troubleshooting steps to help you if ...
? 2:56
https://www.youtube.com/watch?v=IsbMD-Ddcp0
Feb 3, 2012 - Uploaded by SonyListens
Sony VAIO® - Some troubleshooting steps to help you if your VAIO will not power on. SonyListens ..... I have a VAIO laptop & the AC adapter isn't charging the battery. Help? Oh yeah ... It's as if it isn't even plugged in. I've tried ...
Laptop Won't Come On Even When Connecte
Dec 30, 2015 | Computers & Internet
My lapyop automatically switched off when battery got drained .When I tried to restart it ,it is not functioning..There is no light signal and no response for button pressing......
It appears that the AC adapter is not powering the system. If you know anyone with a later model Dell, the AC adapters are inter-changable (If the plug fits, you can use it) If the system powers on, the you need a new (Dell Branded) ac adapter as non-Dell adapters will not charge the battery.
If the DC in jack of the chassis is loose or the LED on the AC adapter goes out when plugged in to the system, then you may have a bad motherboard.
http://support.dell.com/support/edocs/systems/ins1525/en/SM/sysboard.htm#wp1180315
Jul 17, 2011 | Dell Inspiron 1525 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Pictures taken can be reviewed in the camera. But,
It's a one way street...from camera to computer...not the other way around. Doing it that way will eventually corrupt the card and sometimes even the camera.
Jan 17, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak Z740 digital camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
Review Error
HI have you checked your battery's? Seems like when the camera is really low on power is shuts some features off!! Hope this helps :)
Aug 30, 2008 | Kodak EasyShare Z740 Digital Camera
Hi-- This is actually a problem with the Canon LK-51B battery pack that goes with the iP90v portable printer. We've charged up the battery pack and all the lights have gone out, indicating full...
electronics should not be relied on to realy confirm u need to use a second battery pack to connect ur printer n see if the same thing will occure. i guess the battry inside d pack may be dead even though its a new one.
May 24, 2008 | Canon Office Equipment & Supplies
Kodak EasyShare Z740 Digital Camera Logo
18 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
