Question about Homelite 30cc Piston Cylinder Kit Assy Blower Parts
The piston has an little bubble that sticks out about .3 of a millimeter it wont move in the piston how do i get a new one
    President:
  • Homelite Master
  • 1,545 Answers
Not sure here what part you need, but you can check for sure here: http://www.ereplacementparts.com/
You will find parts lists and breakdown diagrams on your model. You can also purchase the part you need here.
Please vote on this solution.
Posted on Sep 10, 2010
Brake pads sticking
Is it the pads are sticking to the disc (never heard of this), or are the pistons not retracting?
If the pistons are not retracting, the could be crud on them, or some corrosion.
Clean them off before pushing back in.
Also, the rubber seals move a little with the pistons when the brakes are applied.
When the brakes are released, the seals try to go back to their original position, pulling the pistons back with them as they go.
Over time (and because of heat) the seals harden and loose their elasticity.
The cure for that is to replace the seals
If you go that far make sure to clean the pistons (see above) and the bores before reassembly.
Jan 30, 2014 | Honda Motorcycles
1996 Ford Taurus GL Sedan Car will not move while running in drive, 2, 1, or reverse. Transmission fluid is at correct level and looks new. No grit or bubbles on stick, fluid is normal red color....
Does the fluid read overfull on the stick now? You might have stripped the splines in the converter for the pump shaft. This is common problem on this model. Also the Forward clutch piston are known for cracking.
Feb 14, 2011 | 1996 Ford Taurus
Have a break calliper with piston that wont push back to fit new breaks what can i do apart from buying a new one
Use a little wd40 or pbblaster penetrating oil and let it soak for an hour. I don't know what you are using to move the piston. What you need is a large C-clamp. Make sure it is an all metal clamp. None of that plastic junk. A few good turns of the handle should start moving the piston.
Dec 31, 2010 | 2002 Isuzu Trooper
Out of timing on the distruber. need to know where rotor button would set on compression stroke, on 350 lt1 engine
pull the #1 plug(drivers side front) bump it around till compression stroke,use a small probe of some sort to feel when the piston is top dead center,then the rotor is to point to the #1 plug wire(just follow the wire to the cap)
Nov 07, 2010 | 1994 Chevrolet Camaro
Front brakes sticking after a couple of miles
There are 2 causes, 1.caliper slides are in need of servicing/lube.2, caliper(s) piston(s) need to be serviced/cleaned. Recommend replacement of both calipers, if either doesn't work.
May 15, 2010 | Cars & Trucks
Trying to fit new pads to vw touran rear axle and have pushed piston back enough to get it off but cant get it back in any further to fit it over new pads and disk, wont fully retract or cant get it to ?
Try removing the brake reservoir cap under the hood where you fill the brake fluid up. This will release some pressure also use a c-clamp if you haven't already to push the piston.
Sep 22, 2009 | 2004 Volkswagen Passat
2003 R6 Rear Brake doesn't function.
I suggest replace all fluid & while the caliper is off for a pad change check the caliper pistons are not seized -"copperslip" around the piston means they will move more freely when you brake. Bleed properly as air bubbles can cause what your describing.
Aug 06, 2009 | 2003 Yamaha YZF-R6
Rear brakes 05 merc montego
Try turning again clockwise with a little more pressure. If the brakes were worn badly the piston is just stuck from being adjusted out so far.
Jul 27, 2009 | 2005 Mercury Montego
BN125 Wont fire
Did you rebuild the trigger plunger? Check the plunger on the trigger. Sometimes junk will set up in the seat and cause low flow of air.
May 27, 2009 | Porter Cable Cable BN125A Factory -...
Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
Homelite 30cc Piston Cylinder Kit Assy Blower Parts Logo
87 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
