Question about Dishwashers
My asko dishwasher(1504) keeps running sometimes, The time will run down to 1 min on the disply and stay there and run on and on until I turn it off. Prior to this another problem occured, when the washer does shut off on it's own, the display will read F1(Falt in the heater), I am wondering if one problem has to do with another. The heater problem I can deal with but not the continueous running.
  • 2 more comments
  • starwars33 Sep 16, 2010
    Thanks Techbuster,
    I noticed a burn mark on what turned out to be the relay for the heater coil. The contacts were pitted and worn and not touching when energized. I took it apart, cleaned and adjusted the contacts so they would indeed contact when the relay was energized. I am looking to ordering a replacement in case this does not last.
    I just ran a wash and had no problems.
    I still have the front panel off the machine and thought I would troubleshoot the rinse aid dispenser since it does not work.
    I measured the continuity of the solenoid and got 325.5 ohms. Does this sound right?
    Thanks
    Mike
    Definitely pointed me in the right direction, was ready to give up before Techbuster's comment.
    Thanks for your help MNfisherman. It turns out it was a relay that was faulty.
    Mike
  • Jeff Dubin May 04, 2012
    Mike - If you still own the ASKO 1504 can you send me a text at 2162444529@vtext.com? I'm looking to buy a used ASKO 1504.
  • 5,081 Answers
F1 doesn't mean that it's always the heating element itself, often it can be the control board relay that has shorted and isn't sending power to the element. If the element is the faulty part, you'd be looking at about $250 for part and labor and trip to replace it. If it was the control board, you'd be looking more at $500 or so with part labor and trip.
The heater would take about an hour or a little more to replace and the control board maybe only 30-45 minutes.
Posted on Sep 16, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Sep 17, 2010
    Sorry for replying late ,I am happy that your problem is resolved
  • 11,896 Answers
This is most likely the timer. It is a common problem. If you wish to, you could test the timer with an ohmmeter on the Rx1 setting and test the continuity of the timer. Chances are likely that the timer is faulty.
I have a ASKO D3111/8 dishwasher that will not stop pumping unless i turn it off at the power?
Hi alan gorman1,
I believe the Float Switch has been activated, do the following:
- Tilt the dishwasher back 35 Degrees.
- Keep it there until water stops running out the side (If any)
- Then tilt the dishwasher forward 35 Degrees
This should empty water trapped in the lower part of the Dishwasher, and deactivate the float switch.
Kind Regards
Jedemeyer1
* Hope this solution helped you, if it did, please rate it.
Jun 10, 2011 | Dishwashers
My Bosch diswasher SHU5312UC runs down to one min and won't pump the water in or out.
hi,theres a overflow swich it the pan under the dishwasher...it might be sticking or your control board behind the disply for 1 min..is bad...call i will fun you through it...
May 12, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
I have a Bosch SHE46CO dishwasher that runs too long. It adds an extra 37 min to the normal wash cycle. It counts down correctly until about 50 min then it adds the 37 min. Also when it get to 1 min it...
it can be the software or anly have a much colder water and it needed a longer time to heat for washing and rinsing. also a heater is damaged and the dishwaser runing at the half capacyty. so long!
Feb 23, 2010 | Dishwashers
Dishes and the dishwasher look dirty after they run, like it redistributed dirty water. The door is very dirty/filmy except right under the soap dispenser, like someone squirted dirty water on it but wiped...
Did you say both of your dishwashers were doing the same thing? Are they the same brand and did you buy them together. It could be a seal in the pumps motor leaking and oil is getting in the water, that is if your pump pumps your water in and pumps it out. Some models the pump pumps the water in and out, other havw a water inlet valve that electrical opens to let water in and the pump just after the cycles pumps the water out.
Dec 30, 2009 | Dishwashers
Asko d1706- drain pump keeps running at the end of the cycle, even in the Off position. Water sometimes remains in the bottom of unit. Any clue
There was a small leak when I re-installed the pump causing water to accumaulate in the base. By reading on your site, I realized that this is normal and expected, for the event that a leak occurs, the pump stays on to purge all possible water.
Thank you
Dec 23, 2009 | Asko D1706 Built-in Dishwasher
Dishwasher won't power off
Howdy. Flashing light on the switch, shows a glass? At any rate your overflow protection switch is activated. Probable cause; plugged or defective exhaust hose that does not allow pumping to go faster than water coming in, too high a water level. Clean the entire system first!
Is your exhaust hose going up to about threequarters as high as the machine? You must have this uphill twist and turn in the drain system.
A little water remains in the sensor and it thinks you are flooded. Force air through the pump in the floor until all is clear, a clean plumber's helper is ideal. Keep doing this until you get the last bit of water out of the sensor. When you get it running watch the machine (First time) carefully. You do not want a flood, that's why Asko put this safety device in place.
Jul 29, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
189 people viewed this question
Top Dishwashers Experts
