Question about Nokia 5130 Cellular Phone
I connect nokia5130c-2 with pc suite6.84 everything is good but a window appear" nokia5130c-2 in mode non-compatible"this is my problem.thank you
  • 10,421 Answers
My swift family ancestry software will not work with my windows 7 pc. I created a family tree and I now need to update the family tree for our reunion October. How can I use my tree and make the necessary...
hello bvanora,
Unfortunately it doesn't appear that your software is compatible with windows 7. Windows 7 does have a compatibility mode which is suppose to let the program run as it would in an older OS. However a little luck is needed, as well as the hardware requirements. such as windows 7 pro, and up. 2 Gigs of memory, and "cpu hardware virtualization support" (although there is a work around for virualization)
To try running your program in compatibility mode right click on the programs short cut, click properties, click on the compatibility tab, check "run this program in compatibility mode", click on the drop down menu and select windows xp, also click "run this program as administrator", and click ok.
If you get an error, along the lines of "Cannot start windows virtual pc" follow the link provided, and download the appropriate update for your computer 32/64 bit. This is the work around i mentioned for virtualization support. So as long as you have win 7 professional or higher, as well as 2 gigs of memory you should be able to run your program.
Good luck
Aug 19, 2011 | Cosmi Swift Family Ancestry for PC
I recently purchased a new computer (HP/Windows 7) and am having difficulty loading my copy of PDFCreate!3. The error message is: "AddPrintDriver Cause of Failure - 2". Is this version of...
hi,
it does appear that even create 4 didn't have windows 7 support. You may try installing and then changing to windowsxp compatible mode by right clicking the icon and selecting properties and the compatibility tab then place a check in "run this program in compatibility mode" and choose windopws xp. and or install virtual PC with windowsxp compatible then install and run your older software in a virtual machine.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 08, 2011 | Computers & Internet
WHEN I START MY GAME IT COME OUT WITH A BLACK SCREEN FOR A SECOND AND GONE SO WHAT SHOULD I DO?
May i know what Operating System are you Using?Are you using Windows 7 or Windows Vista?
If your using the mentioned Operating Systems above, then maybe the problem is, the game is not compatible with your operating system. Here try using this method if it will work ( Beware that Im not 100% sure that this will work. but theres no harm in trying, RIGHT? )
  1. Right Click the shortcut of Pizza Connection 2 in your Desktop.
  2. On the menu that will appear, choose Properties.
  3. On the properties, click the COMPATIBILITY tab.
  4. Now on the Compatibility Tab, Go to Look at the COMPATIBILITY MODE, you will see there a sentence like this: " RUN THIS IN COMPATIBILITY MODE FOR: "
  5. Now on that part, you will find a drop down list where different kinds of Operating System
  6. Choose Windows XP ( This will make the game run in XP COMPATIBILITY MODE )
  7. Now Click Apply and Then Click on OK.
  8. Thats it, Try running the game again.
Hope my solution will work and will help you, Please give me feedback regarding my solution thank you very much.
Jul 06, 2011 | 2K Games Pizza Connection 2 for Windows
SIR, GIVE THE DRIVERS FOR WINDOW7 FOR UMAX ASTRA 4100
Unfortunately, Umax doesn't appear to be offering much in the way of online support for their older model scanners. Your model doesn't even appear in the drop-down menu on their Support page.
If you still have the original CD containing your scanner software, try installing the Windows XP
driver in Compatability mode:
1) Locate the .exe file for the driver.
2) Right-click on the file, and select Properties.
3) Click on the Compatability tab, and check the box marked
"Run this program in compatability mode for Windows XP."
4) Click Okay to close the window, and install the driver.
Good luck! I hope this was of some help.
Jan 08, 2011 | Computers & Internet
Uniden Trax 5000 - unable to use Trax Central
Had the same problem with Trax Central software. Ended up successfully using Naviextras Toolbox application. https://www.naviextras.com/shop/portal/downloads
Still don't know what, if any, extras on the Trax Central software. I tried to get it to run on 3 XP boxes and 2 Windows 7 boxes. Gave up in disgust. Good one Uniden.
Mar 22, 2010 | Uniden GPS
Razer wireless mouse wont work in PC mode on mac
I think you are using a Non- Windows specified Driver. If yes then you will have this problem. Try a Windows Driver ( the Windows which you have ). Also if it doesn't solve, check that is the Program is running in the compatibility mode of your windows.
Thank you, Have a nice day.
Sep 28, 2009 | Razer RZ01050300 Mouse
Can't get on Easyshare
Try the steps below.
1. Right-click the EASYSHARE icon on your desktop
2. select Properties.
3. Select the Compatibility tab.
4. Clear the Run this program in compatibility mode check box.
5. Click Apply, then OK.
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak EasyShare One Digital Camera
Hi-speed USB device plugged into non-hi-speed USB hub
Hi Shiva,
Did you try to boot into your BIOS and check the settings for your USB port? Often you can set the compatibility mode there.
Secondly, try to connect the usb device to different USB ports on your PC, they might not all be connected to the same controller (front or rear for example).
Jules
Aug 24, 2008 | Microsoft Windows XP Professional With...
Nokia 5130 Cellular Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
