Question about Maytag Microwave Ovens
MMV5100AAB Over the Range 1500 watts 3amps -turntable does not turn -does not heat -light works- unit makes loud running noise but will not turn off -must open door or unplug to turn it off. Never any problem til we started to heat some food. Thanks for any help.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 10, 2010
Glass tray turntable makes noises when heating food
Hi, the rollers on the support mechanism has residue, try cleaning the rollers and the track it follows, should resolve the sound problem
Jan 05, 2015 | LG LMH2016ST 2.0 cu. ft. Over-the-Range...
Why is my microwave model 60609 making extremely loud noise and not heat?
Usually that is a sign that your magnetron tube has gone bad (shorted out).
Jun 10, 2014 | Kenmore 80822 80823 80824 80829 1500...
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Microwave will not heat, but will turn on. Clock and Timer still work. Turntable turns. Making a loud humming noise and light flickers
This clearly indicates a bad magnetron, "heats food" in most cases it is cheaper to replace the microwave oven than have it repaired, since the magnetron is the heart of the unit.
Mar 01, 2012 | Microwave Ovens
KitchenAid KCMS1555RSS stopped heating. Everthing else works, full display works, time counts down, turntable rotates, light comes on, etc. but no heat. makes loud hum. Magnatron? Cost to replace? Unit is...
If it is making a loud noise, check the diode and magnetron for damage.
BEWARE OF LETHAL VOLTAGES!
The fault may be just the diode and a reasonable cost will be involved. If it is the magnetron, depending upon where you purchase one from will command the price.
Hope that helps.
Nov 13, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Display works, turntable turns, but it won't heat.
If it making a loud humming or buzzing noise when it is turned on, it could mean that the magnetron has failed. If that is the case, then it typically not worth fixing, since the cost to repair is almost as much as a new oven.
Aug 23, 2010 | General Electric JEB1860 1100 Watts...
Makes loud noise and doesnt heat. Timer, clock, turntable & other things work. Model # 665.61632100
Most likely the magnetron is bad. I'm guessing a household model. Unplug unit and unplug the connection at the magnetron and run again. The noise will likely be gone. If you do replace the magnetron, replace the diode that goes with it.
Sep 10, 2009 | Microwave Ovens
SPORADIC HEATING
check highvoltage crcuit ,and check fan, and turntable motor,
Oct 18, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Turntable does not turn and fan won't exhaust
The second problem is probably defective door switches, or it may be a problem with the control panel, which we repair nationwide for only $32.50. On my Web site, I have info on safety, disassembly, and diagnosing and replacing door switches: http://tinyurl.com/yzjozk Running it empty has damaged the magnetron. It will work for a while, but it will eventually have to be replaced. A good parts source is here: http://tinyurl.com/gv383
Jan 05, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
151 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
