Question about Whirlpool Washing Machines
Washer will not aggitate in rinse cycle but every thing else works fine
    President:
  • 3,773 Answers
This involves the spin lid switch
Twist timer very fast a few times and stop it on spin with the lid closed. Wiggle the timer to get the points to connect. Even if you
just get a little bump then its the timer.
If none of this works then it is the timer plus maybe something else contributing.
You can tape the two wires to the switch together and it'll work just fine
Also check the plunger on the lid to see if it is not broken off
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 10, 2010
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
