Question about GE WJSR2070B Top Load Washer
Why my ge washer will not cut off by the timer
    President:
  • 3,773 Answers
If every thing else works o.k. then you have to replace the timer.
Give the timer knob a few sharp turns aronud the dial to see if that helps.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 10, 2010
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
GE washer not spine
First thing you can due is to manually move the time to drain and spin mode. This will check your timer to see if your timer is working. If it start working then it is your timer. It will be your timer gone bad.
Dec 05, 2009 | GE Washing Machines
How to I access the timer switch on a GE electric
All ge washer timer is access by taking the four screws off at the top of the background. Sometimes there is six on some models. General there is four. Pull the back gaurd out and you should have access to the timer. A warning unplug the washer before doing this, you can get a shock.
Nov 07, 2009 | GE DBSR453EBWW Electric Dryer
I have a GE WJRR4170G1WW washer. Instead of going
Just wanted to let you know that the solution in the comments worked for my dishwasher!! Save me a service call and some cash!! Thanks Spencer.
Oct 06, 2009 | GE WBSR3140DW Top Load Washer
GE Washing Machine That the Water Does Not Cut Off!
your washer valve is sticking, it should probably be replaced
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Need to find an Eaton timer for a GE washing machine ( 20 yrs old) Eaton part number 114-317-20 1/3 rpm, 115 vac. thanks Bob Westerdale PS- not sure of the model number on the washer. label is missing.
What is the GE part number it ? What is exactly the problem with the timer? Is i the AC timer motor or is it the contacts? You may be able to disassemble the timer & repair it.
Ebay is also a source for older parts.
Jun 08, 2009 | GE WDSR2080D Top Load Washer
GE WASHER, REPLACED TIMER THEN BIG SMOKE
Be sure you are using the EXACT replacement part. The wiring may be different if it is a "close" match.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Washing Machines
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
GE WJSR2070B Top Load Washer Logo
47 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
