Question about GE Refrigerators
Refrigerator and freezer won't keep things cold enough. reezer, cold but won't keep things frozen. Already vacuumed fins and cleaned out compressor compartment.
  • t059 Sep 10, 2010
    how old is it
  • jg19319 Sep 10, 2010
    ABOUT 10 YEARS. I T WAS DOING THIS ABOUT A MONTH AGO AND THEN STARTED TO WORK NORMALLY. I NOW HAVE BOTHH CONTROLS ALL THE WAY UP. THE REFRIGERATOR IS KEEPING THINGS COOL BUT NOT COLD, THINGS GO BAD QUICKLY. THE FREEZER ARE ALSO KEEPING THINS COLD BUT NOT FROZEN.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
  • 101 Answers
Sounds like a sealed system problem
Posted on Sep 12, 2010
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Freezer was freezing up. Technician came and thawed it up and got it cooling as it should; however, the freezer is only getting to 40 degrees. It is not making ice. It is not cold enough to keep my food...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 19, 2011 | Northland Pro-Chef Model, Three Door,...
Kenmore side by side....freezer is not staying cold enough to keep ice cream frozen, middle wall between frig and freezer is extremely hot.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Mar 01, 2011 | Kenmore Side by Side Refrigerator
Compressor conning on for only approx 10 seconds and off for approx 30-60 seconds continuously. Freezer not cold enough to keep things frozen
Check condenser is cleaned. Replace relay and check compressor is working. If working keep your arm on condenser coil to feel warm. If not, no gas int he system. Call repairman to rectify. And also keep fridge temp setting between 36*F and 46*F and freezer temp between -14*F and 8*F. Thanks.
Feb 12, 2011 | Maytag MTB2195AE Top Freezer Refrigerator
Freezer is not staying cold enough to keep food frozen
Refrigerator
heatman101
Jan 16, 2011 | Whirlpool Refrigerators
ALL THE SUDDEN FREZZER WILL NOT GET COLD ENOUGH TO FREZZE POP SICALES BUT IT STILL WILL MAKE ICE ANE ITS BARELY IS KEEPING THING S FROZEN. THE REFRIGATOR PART WORKS GREAT CAN YOU GIVE ME SOME SUGGESTIONS
heatman101
Nov 19, 2010 | Kenmore 56239 / 56232 / 56234 / 56236 Side...
The freezer is not keeping items frozen. It is blowing cold air but not cold enough..
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 06, 2010 | Maytag 22 cu. ft. Bottom Freezer...
Frig not getting cold enough. Freezer section
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 19, 2010 | Kenmore 21 cu. ft. Top Freezer...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
