Question about Shelcore Toys Toys
We have a Shelcore windup mini musical carousel from 12 years ago. It seems a mischievous young friend has overwound our beloved toy. We tried tapping it on the bottom and heard a brief, fast, whirring sound but alas we cannot get the song "My Little Playmate" to play. We are afraid to unscrew the bottom lest the toy pieces fall out and we don't know how to put is back together. PLEASE HELP US!!!
fairlane
  • 50 Answers
SOURCE: Reads CD's but not DVD's
Hi I responded to Parisica's problem, so you have read the "bad news" already. All I can add, is that we see your problem quite often, and without spouting a bunch of tech jargon, lets just say it is easier for the laser to read Cd's than DVD's, so quite often when the laser begins to fail, DVD's will no longer play, but Cd's are fine. I'm not an expert on your model, but Parisica mentions a menu setting that turns DVD video on & off, which may be worth checking, and also cleaning may help, as a dirty laser lense can give the same symptoms as a weak laser. I don't want to get your hopes up, 2-3 years of service can certainly be long enough for laser problems, depending on how much you used it. Good Luck!
Posted on Aug 15, 2006
ctf1800
  • 4402 Answers
SOURCE: Remove random play
go back all the way in the menu till you get to the begining and select music library, then go back to play mode and select normal
Posted on Jan 18, 2008
bargainbox
  • 1388 Answers
SOURCE: Putting back the pieces of bobbin case on Kenmore Mini Handi
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Posted on Feb 29, 2008
SOURCE: fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Posted on Jul 09, 2008
hardkiss69
  • 43 Answers
SOURCE: CD rom drive wont open!!!
Hi, it only means that the drive is already damage and you need to contact the manufacturer of your computer and verifiy if your computer is stil under warranty so that they can replace the drive with no additional cost but for some reason if you have physically damage the drive then you will be charge for the said repair so it depends on the warranty of the computer.
Hope this helps!!!
Thanks
Posted on Sep 18, 2008
Hello, my name is Susi & I live in the UK. At Christmas 17 years ago I bought a Maisto Santa's Carousel Park. But 12 years ago I lost the adaptor that came with it. I asked ppl & tried other adaptors but...
Maplins sell an adapter that has multi-voltage settings and a whole array of connectors, I'm sure they have what you require. Check online, they have a questions part too that is usually very helpful. Find an adapter on the site and you can ask a ? about it... and get an answer too ! .... Good luck... Red.
Dec 03, 2014 | Computers & Internet
I cant recieve incoming call
Not all mobiles are mobile phones.
The Kidsline Cherry Blossom Musical Mobile sure is a mobile, but not a mobile phone.
That is great, because it is not healthy to put a mobile phone so close to our little beloved ones.
May 11, 2014 | Kidsline Cherry Blossom Musical Mobile
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Where can I get hold of a sing a long microphone? My friend said that V-tech were a good make to buy.
Here's a link to the Kiddicare site;
http://www.kiddicare.com/webapp/wcs/stores/servlet/productdisplayA_290_10751_-1_15059_69929_10001_15056
They are good for young kids as they have additional sound buttons that you can press on the side.
Feb 25, 2013 | Toys
I have a wrebbit music box that's complete but no instructions. where can i get them
I have scanned the Instructions and the Annex instructions. You can view and download them from here:
The Enchanted Carousel Instructions - Wrebbit
https://docs.google.com/open?id=0B5flfeMskegmYWVlZTZjODYtMGU1ZS00ZDRmLTg3YTEtMTI4MzBkZTFhYmNi
The Enchanted Carousel Annex Instructions - Wrebbit
https://docs.google.com/open?id=0B5flfeMskegmYWZkYWI5NGEtOWEyOC00OTRmLTg2MDEtNWUzNWU1NzM2MWJh
The directions for installing the music box are in the Annex Instructions.
Sep 21, 2011 | Wrebbit Enchanted Carousel Wrebbit 3-d...
A page from the instruction manual was missing and now i have no idea where the music box goes. Where does it go?
Aug 05, 2011 | Wrebbit Enchanted Carousel Wrebbit 3-d...
Zoom (4) MAISTO - SANTA'S CAROUSEL PARK - MUSIC BOX i lost the ac dc adapter i tied ti find another adpter that may fit but with out luck . my mother asks me every year can you find adapter ...
It it looks like this one:
Maisto
Model# DPX412012
INPUT 120V AC 60HZ 9.8W
OUTPUT 6V DC 800MA
CLASS 2 TRANSFORMER
A wonderful person on EBay, seashells-resale-by-the-seashore, gave me this information for my husband's carousel. It had been a gift to his mother who passed away. Now we can get it working for the grand & great-grand children.
Dec 16, 2010 | Carousel Toys
How do I patch holes. There seem to be a couple causing part of the carousel not inflating
I used gaffer tape, seems to work perfectly. Adheres well and it's stronger than the original material anyway. Hope this helps.
Dec 09, 2010 | Carousel Airblown Inflatable Christmas...
We have a Gemmy airblown carousel with four figures inside. It will only partially inflate. We have unzipped everything and untwisted everything. The bottom inflates and part of the top but nothing in...
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
Nov 29, 2010 | Carousel Airblown Inflatable Christmas...
Large music box carousel will not turn/play. I believe it was wound too tight.
I believe you are correct in your assumption.You could try taking it apart yourself to check if it's the spring,but I would take it to a clock/watch maker. They are familiar with these sorts of things and could repair it easily.
Hope this helps.
Sep 15, 2009 | Carousel Toys
Toys Logo
98 people viewed this question
Top Shelcore Toys Toys Experts
ray gallant
Are you a Shelcore Toys Toy Expert? Answer questions, earn points and help others
