Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with EZ-Change Ice and Water Filter
Both sides are not cooling . The motor is running and the lights are on but it is warm only. What do I look for.
  • Whirlpool Master
  • 43,501 Answers
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Sep 11, 2010
Why is my sub zero fridge model 590 warming up?
Hi fridges will warm up on the outside as they remove heat from the inside. excessive heat with not extreme cooling inside the fridge indicates a possible degridation of coolant fluid or a leak. as the motor tries to cool the fridge the thermostat inside stays on as the tempreture inside has not been reached. if you hear the motor/ pump continually running this will indicate a cooling problem.
May 28, 2014 | Sub-Zero Refrigerators
Samsung model rs263osh lights on but refrigerator or freezer doesnt cool
hi bobby.both not working is not agood sign.pointing to motor falure. but try servicing the condenser unit first u might get lucky.remove rear panel and con/fan and motor should be running and cond should be warm.try this first good luck.ali
Aug 21, 2012 | Samsung RS2630SH Side by Side Refrigerator
Cooling fan motor will not run i just replced
driver side strut tower
firs and last relay any way u want to look at it dont mind the other relays just the two outer relays
make sure the ecu signal is working
warm up the car and disconnect fan motor make sure tha you have ggod ground get a test light and check for the litr green wire to see if its going to send signal to the wire
Jun 12, 2010 | 1993 Dodge Caravan
Both sides are warmer than should be. motor running nonstop
You refrigerator needs regassing that is why things are not cooling. Your sides of fridge are hot because the motor keeps running to keep what gas is there flowing though the lines trying to cool fridge
May 25, 2010 | Maytag MZD2766GES Side by Side...
Door alarm on and not cooling
If its the door alarm specifically, and not a temp alarm, assuming the door is closed of course check a couple of things. When you say its not cooling, is it not cooling in both sides, one side, part of either or both sides - i.e. top is warm and bottom is cold? My first door alarm thought was its possible door switch is bad, causing both light to stay on and alarm to think door is open. Is it especially warm or hot near a bulb in either side? If its warm at top, I would look into your evaporator fan motor operation, If its not cold on one side and cold on other, that could be several things, too many to list without specific temps.
Visit: www.FixMyFridge.net for Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
Mar 22, 2010 | General Electric GSHF5KGX Side by Side...
Motor runs for a few seconds than cuts out. No cooling
The startup capacitor is weak and that makes the overload switch kick in. You can get a 1/4 hp to 1/3 hp 3 in 1 hard start relay to fix that from graingers, or 1stsourceparts. EZ instructions.
Mar 10, 2010 | Refrigerators
My cda554 beko refrigerator not cooling
hello there.........is the refrigerator motor running...(not the fan)...if this is running...pull the fridge out for access.....check the smallest diameter pipe on the compressor for heat.(not the small charging stub which goes nowhere)...in normal operation this small pipe should be quite warm to hot.....if its not it is possibly due to an internal gas leak....fridge motor will run but not cool the fridge.....if the motor isnt running but the internal fridge light is on when you oen the door it is possible the thermostat (temp control) needs replacing
Regards Sir Galahad
Jun 22, 2009 | Frigidaire FRS26R4A Side by Side...
New fridge will not cool or freeze
By motor do you mean fan or your compressor is running if your compressor is running but it is not getting warm to the touch then you have no refrigarant in the system
Mar 31, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fresh Food & Freezer Warm
CHECK AND MAKE SURE YOU CAN HEAR YOUR EVAPORATOR FAN RUNNING (INSIDE MOTOR). IF IT IS NOT RUNNING ... AND YOUR COMPRESSOR IS RUNNING. THE MOTOR OR DEFROST TEMENATION SWICTH COULD BE DEFECTIVE. IF NOTHING IS RUNNING ... TRY TO LOCATE THE DEFROST TIMER(USUALLY LOCATED WHERE YOUR COLD CONTROLS ARE) YOU SHOULD SEE A SMALL HOLE WHERE YOU CAN MANUALLY TURN THE TIMER WITH A SCREW DRIVER.IT CAN ONLY TURN IN ONE DIRECTION. IF THE MOTOR IS RUNNING. CHECK TO SEE IF COMPRESSOR IN THE BACK IS RUNNING ... IF IT ISNT AND IS "HOT" (BE CAREFULL) SEE IF THE CONDENSER MOTOR NEAR THE COMPRESSOR IS RUNNING ... IF NOT ... THE COND. MOTOR IS BAD ... THAT MOTOR RUNS IF POWER IS GOING TO THE COMPRESSOR ALWAYS. IF COMPRESSOR IS HOT AND NOT RUNNING AND COND. FAN IS RUNNING .... UN PLUG FRIG AND WAIT TILL COMPRESSOR IS COOL TO THE TOUCH. THESE COMPRESSORS HAVE AN INTERNAL T-STAT THAT PROTECTS THE COMPRESSOR IF IT SHORT CYCLES.IT SOMETIMES GETS SO HOT IT DOES TAKE HOURS TO COOL OFF. THERE IS ALSO A DEFROST-TERMINATION SWITCH THAT CAN GO BAD. CONSULT A LICSESED FACTORY CERTIFIED COMPANY TO GIVE YOU A FIXED-PRICE DIAGNOSTIC TEST.
Apr 24, 2007 | Frigidaire FRS23R4A Side by Side...
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with EZ-Change Ice and Water Filter Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
