Question about Adobe Dreamweaver CS3 ( Windows ) for PC (38040335)
Hi, just got a new tower running XP Pro (a downgrade from Win 7). Installed several programs including CS2 with no problem. Went to install Dreamweaver CS3; clicked on the icon and saw that the initialization started...then the initialization stopped and nothing else happened. Tried selective startup with same result. Any ideas? Thanks, Steve
  • 6 more comments
  • email663 Sep 10, 2010
    Hi Tim,
    Here are answers to your questions:
    1. Rebooted several times...same result.
    2. The CS2 suite works except for one thing: Adobe reader opens but the licensing screen is blank (white page). Upon closing the window the message is something like: License Agreement not accepted. The application will now quit.
    3. The disc is the original CS3 from Dreamweaver.
    4. CS2 was installed prior to attempting to install Dreamweaver CS3
    5. The initialization window shows that files being transferred, the progress bar moves rather quickly and goes to the end, then the window closes...and nothing further happens. Typically, you would see a new window open with continued prompts for installation.
    6. Yes, the same thing happens each time...with or without using selective startup.
    7. Another quirk: If attempting to install via the control panel, Dreamweaver shows up in the list of installed programs, but with no data size indicated. Upon selecting Dreamweaver, the window locks up and has to be closed manually.
    8. This new tower is a workstation only and is not connected to a network or to the internet.
    Hope that helps you figure this one out....thanks, Steve
  • email663 Sep 11, 2010
    Hello Tim,
    ...followed your instructions and downloaded the uninstaller program. Got rid of all Adobe programs and common files as well as any Adobe registry entries.
    Then...tried to install Dreamweaver CS3...SAME RESULT!!! The program initializer went so far, shut down and nothing else. I did notice that some remnants of the program were installed according to the uninstaller program, so I got rid of those and tried again but had the same result.
    Question: How do you install to another directory? Thanks, Steve
    Hi Tim, Thanks for the suggestion...however, the install doesn't get that far. As described, the initialization window (with the files that fly from one to the next)...comes up, the bar fills up quickly and then disappears and nothing else happens. Using the uninstall program I can see that some files were transerred, but no program data. After looking around on the internet, it seems that others are experiencing a similar problem using Vista with Dreamweaver CS3....but we purposly asked the PC builders to use XP Pro. And yes, the CS3 disc was used on 3 other machines running XP to install on them...with no snags. Any other ideas? Thanks, Steve
  • email663 Sep 12, 2010
    Hi Tim,
    Here is a link to the system specs. The only difference is that we ordered the machine with a larger capacity hard drive. The system you want to look at is the BX-680. There is no anti-virus software installed and there is no Flash player installed (as yet). This is a new machine that we picked up last week...which was to be used in a production area for web development. It is ironic that one of the key programs, Dreamweaver CS3 will not install. Hope the info helps. We did contact TPI regarding the problems we are having and we may just return the machine and get another one with different hardware. So, your feedback will be valuable to see what hardware we may need to be compatible with XP and with Dreamweaver CS3. Thanks.
    Sorry...forgot to embed the link to the TPI site, again scroll down and look for the BX-680:
    http://www.tpi-us.com/products.php?cat=7... Thanks again, Steve.
    Hello again, ...forgot to mention that, yes, the latest service packs have been installed. Steve
    Thank you Tim. I will be contacting TPI tomorrow ...will let you know what develops. Steve
  • email663 Sep 14, 2010
    Tim (micromatikal) was very helpful...thank you. Steve
    President:
  • 2,777 Answers
I assume you have tried simple things like rebooting? Does your CS2 installation still work? Is it an upgrade disc that you are using? Do you have dreamweaver CS2 already installed? If so that could cause an issue. Does it stop at the exact same point every time? Thanks, please let me know and I can help.
Tim
Posted on Sep 10, 2010
  • 4 more comments
  • Tim Grayson
    Tim Grayson Sep 10, 2010
    Wow, that's all very wild for sure! Hmm, very strange indeed. Ok what I would do is uninstall at least Dreamweaver CS2 if not the whole CS 2 suite (since you are having those user agreement issues. I personally would use REVO Uninstaller (you can get the freeware version, works great) check it out at :
    http://www.revouninstaller.com/revo_unin...
    Eradicate all instances of CS 2 is what I would do, just to test and see if you can then install CS3 without issues after that. You may want to try installing into a different directory to make sure it's not using libraries that were somehow corrupted during the first install.
    Do that, I have to run somewhere real quick, report back anything you find, or at least a reminder that you are still working on it, and I will add more comments here in a bit!
    Thanks so much
    Tim
  • Tim Grayson
    Tim Grayson Sep 11, 2010
    During the install, it should have an option for ADVANCED installation or something along those lines. If it does (or even if it doesn't) it should take you to a portion where you can adjust the directory it installs to. It will display something like C:\Program Files\Adobe\Dreamweaver or similar. So if they have the advanced option, chose it, if not, just keep an eye out for the portion I mentioned there. You will want to click in there and adjust it (should be able to just type in the box) to something like C:\Adobe\Dreamweaver Just change it to anything different then the default, you can't really pick a "wrong" location. If it doesnt let you type in the box it should have a "chose folder" option where you can click and select you C: drive for example and click ok.
    Have you ever used this CD to successfully install before? I wonder if somehow you have a corrupted disc, it can happen sometimes...
    Tim
  • Tim Grayson
    Tim Grayson Sep 12, 2010
    Oh sorry about that, I misunderstood and was thinking it got past the initial setup options and then during the final phase of the install (where it actually copies all files to disk) it was failing. It sounds like it isn't even getting past temporary files which is strange indeed. You have all the latest service packs an everything that windows recommends you update in fact updated correct?
    It could be a general issue with the hardware you are running and XP not recognizing it correctly. Do you have the make / model of the computer available and I can check that potential issue out? Or is it a customer build, and if so, do you know what motherboard, CPU, and video card you are using?
    Also, do you have any antivirus running? I feel I may have already asked this, but checked over the comments I've made and didn't see it so I wanted to make sure. Sometimes antivirus can block installation of some software, but I doubt it's the case, but want to verify.
    Do you have adobe flash player installed? If so, which version? You can check that out by going to this link:
    http://www.adobe.com/software/flash/abou...
    Half way down the page or so it will display the version information, for example mine is:
    You have version 10,1,82,76 installed
    Thanks, sorry it took so long to reply
    Tim
  • Tim Grayson
    I believe part of the issue may be using the Intel Core i3 processor with XP, it is definitely made for a much newer system. If you continue to have issues I would definitely recommend returning it and getting one with a Intel Core 2 Duo or equivalent processor. These are much more compatible with XP... and should be plenty fast enough for you to do all the graphic work you need, just make sure you get plenty of ram (4 GB or more in my opinion) and you should be much better off from a compatibility standpoint.
    Let me know what ends up happening, I am sorry you are having all these issues :(.
    Thanks
    Tim
  • Tim Grayson
    No problem Steve,
    It is my pleasure to help you out :).. Definitely let me know what turns up.
    Thanks Tim, I am returning this machine and getting an "older" processer, which should run XP pro (and the Dreamweaver CS3). Steve
Can I downgrade Acer AOD255-2509 from Win7 Starter to WinXP?
you can install win xp ... as a second os ,,, or you can uninstall win7 and install a fresh copy of xp ,,, but you may need a copy of xp with ahci drivers included or else you'll get ( can't find any hard disc ) message ... win7 don't support upgrading or downgrading from another windows version (vista,ex...etc ) or to another version ...
Mar 08, 2012 | Computers & Internet
Hi, I have used printmaster premier 7.0 for a few years on my old computer and have loved the program. The problem I am having is I bought a new computer that runs windows 7. I tried to install printmaster...
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
Sep 15, 2011 | Mindscape PrintMaster Premier 7.0
Dear sir/mam I want to install win xp in a win 7 installed laptop, (compaq 510) but there was some error to install it (blue screen error). Sir please help me to install win xp the same system with...
You cannot downgrade Windows 7 from Windows XP by not reformatting the hard drive. You need to Remove Windows 7 first, before installing Windows XP Operating System. In order to use the Windows XP CD to fully reformat the Hard drive, follow the steps on the link below.
http://www.windowsxpprofessional.windowsreinstall.com/indexinstallguides.htm
Apr 04, 2011 | Computers & Internet
Just installed Windows 7 Computers and am getting Paradox Version Error: The design object, ':StarLib:L$_ErrorHandler.lsl', could not be opened. Unable to load ErrorHandler Library. I click OK and this...
It seems to me like this program is not designed for Windows 7.
This has happened many times. Microsoft always upgrade but, do not include the words, " Previous Software may not work with new O/S. "
Im afraid this software will not work on Win 7. Sorry.
However you could try to ask Corel online if they have an upgrade, for this prog,for win 7. Hope this helps.
Nov 22, 2010 | Corel Paradox 9.0 for PC
My computer is win 7 but the driver is olny for win xp and vista what can i di plzzzz help me
<P><A href="http://www.microsoft.com/windows/virtual-PC/download.aspx">http://www.microsoft.com/windows/virtual-PC/download.aspx</A>&nbsp;</P><P>Download Windows XP Mode </P><P>Windows 7 has several built-in tools to help with <STRONG><A href="http://windows.microsoft.com/en-us/windows7/What-is-program-compatibility" target=new>program compatibility</A></STRONG> and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs some older productivity programs that might not run on Windows 7. Visit the <STRONG><A href="http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx" target=new>Windows 7 Compatibility Center</A></STRONG> to find software that works with Windows 7. </P>
Aug 27, 2010 | Optics
Hi I have just updated my laptop to win 7 but i,m old fashion and still use Frontpage 98 yep I now old hey is there anyway I can get this to run on windows 7 or am i up for a new version
Like you I use Windows 7, and can tell you instantly that some older Microsoft programs do not work with Win 7, whilst some other ones do. If you have Windows 7 Professional or Ultimate you can try running Frontpage in Administrator and Windows XP compatibility mode.
Windows 7 Professional and Ultimate instructions:
A. Right Click on the Program name if installed (Could also try with install too if not installed)
B. Click on 'Properties'
C. Select 'Compatibility Mode'
D. Try using the different 'Compatibility Modes'. I would try 'Windows XP Service Pack 1' first, if this does not work, try 'Windows 98'
E. Click 'Apply' then 'OK'
F. Right click on the program name that you selected compatibility mode for above, and select "Run as Administrator"
G. Follow any further instructions
If this does not work, then it will probably be cheaper to find a used newer version on a site like eBay. Note that Frontpage 2002 has Windows 7 issues too, so please check out the following links.
Good Luck
http://social.answers.microsoft.com/Forums/en-US/w7programs/thread/649f6c9a-4b7e-4557-b136-bf90b3b3c9e2
http://www.microsoft.com/windows/windows-7/compare/default.aspx
Apr 25, 2010 | Microsoft FrontPage 2003
Old program won't run on new computer win XP but runs on others
> ran slow
Probably, having more RAM would make VMWARE run faster.
> except Sound Laundry 2.5
Check the manufacturer's web-site -- surely, they have a version which *DOES* work as a "native" application under Windows XP and Windows VIsta and Windows 7, i.e., no need for "compatibility settings".
Nov 05, 2009 | HP Pavilion A6400f Desktop PC, Refurbished
Qualcomm cdma msm tataindicom driver missing in Windows 7
Hey, there
I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
Best regards!
Sep 15, 2009 | Computers & Internet
How to downgrade vista to winxp pro at Hp pavilion DV4-1204TU ?
Well, this may make you think twice:
I bought a presario from circuit city last year, and I paid $200 to downgrade to XP. Everything was fine until it crashed last week. IT went completely bizzerk. HP won't provide support, cause I changed it. Circuit City is out of business, not much help there.
Basically, I am completely #$%%@@.
I am now paying to get Vista put back in. :-(
Jun 09, 2009 | HP Computers & Internet
Downgrading from Vista Business to XP Pro
Why dont you give Windows 7 a whirl. Im running it and so far i like it better than xp and it stomps vista into the ground.
If your wanting to downgrade to Windows XP pro, Your going to need to reformat the PC. Simply put the media in the drive restart the computer and boot off the CD-Rom and follow the simple instructions.
May 21, 2009 | IMSI TurboCAD Deluxe 10 for PC
Adobe Dreamweaver CS3 ( Windows ) for PC (38040335) Logo
44 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
