Question about Kohler Fort© Single Lever Handle Kitchen Faucet with Side Spray Polish
My single control faucet is leaking on the side, do I have to replace the whole unit or just the part inside. Also is there any detail diagram of the faucet? Pls. need help
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Kohler should provide you with a rebuild kit for free. Contact them at 1-800-4KOHLER. This is the parts breakdown for your Kohler faucet.
Posted on Sep 10, 2010
I have a Koiler A112.181M or 157-076-ST kitchen faucet. On the back there is a small hole and it is leaking.. What can I do to stop the leak( A small drip) Thank You Jeff
If there is a hole on the spout itself then you should go ahead and replace th.e whole faucet. This will save you both time and money in the long run
Sep 08, 2010 | Kohler Model 10433: Fort® Single-control...
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
Tip
How to repair disc-type faucets
DISC-TYPE FAUCETS
  • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
  • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
  • Use pliers to pull the disc assembly out of the faucet.
  • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
  • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
  • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
  • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
  • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
I have a moen kitchen faucet with spray (high spicket) and a leak is developing at the bottom of the spicket. i may need a washer, but i do not have a diagram. i believe the model number is kvn01-01. thank...
If no satisfaction from Moen, hardware stores usually have "O" ring replacement kits by faucet type, and it will likely have the one you need in it.
Usually only a few dollars.
Jan 04, 2010 | Moen 87530 Touch Control Single Handle...
Our jameco kitchen faucet has no water pressure. also we have a slow leak on the cold water side. The faucet is only 3 years old. we took the cold side apart and there is no washers, only an o ring that...
Sounds like you may need to replace the cartridge if you have one of the late model single control models. You may get a clue as to how your faucet might be put together by finding a similar faucet on the Moen web site, and looking at their exploded parts diagram. (They are good about posting information; although some say their products are not so good; I really don't know personally)
Dec 14, 2009 | Delta 2402 Classic Single Handle Kitchen...
The cartrige inside my moen faucet leaks
moens website. they have parts break down and diagrams
Nov 30, 2009 | Moen F7425 Chateau Single-Handle Kitchen...
Single lever kitchen faucet,seal broken
To address the leaking problem fast, you may replace
the whole set.
1. Shut off the main water valve.
2. Take the leaking kitchen faucet off.
3. Replace the defective kitchen faucet.
4. After replacement, open the main water valve.
Of course, you could have repaired it. That is assuming that you could easily find the right seal.
Besides there is no guarantee that the location where
the seal will be placed is still not wornout.
Nov 29, 2009 | Plumbing
Moen one control shower faucet is leaking hot water
Try replacing the cartridge first.That's your best bit . Next would be the whole valve. Hopefully, it's just the cartridge.
Jul 04, 2009 | Moen & One Handle Tub & Shower Faucet
Mixet single control shower facet leak
did you replace the seats and springs too? if not this may fix your problem.
May 28, 2009 | American Standard 2385.003.002 Reliant...
My price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Dec 26, 2008 | Price Pfister Ashfield Single Control...
Kohler Fort© Single Lever Handle Kitchen Faucet with Side Spray  Polish Logo
1,118 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
