Question about GE 24 in. GLD5500L Built-in Dishwasher
Dishwasher will not fill with water. I've already checked the float assembly, that seems to be working fine. The water just doesn't seem to run into the machine. Little history on an unrelated problem: I want to mentioned that not to long ago my brother tried to put a bunch of celery through the garbage disposal. The sinks and pipes got all clogged up and we had to take them apart to clear up. Immediately afterwards the dishwasher stopped filling with water. I don't see how the two can be related but I thought I should mention it.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 10, 2010
Does not fill with water.
follow this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 08, 2013 | Thermador 24 in. DWHD64CS Stainless Steel...
Water only dribbles out of lower spray arm during cycle and spray arm doesn't turn. checked filter, water lines etc. If it's a motor or pump that needs to be replaced, how do I get to it?
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Sep 03, 2011 | Bosch Dishwashers
The dishwasher does not fill up with water, but when we manully add water, it seem to run through cycle. also, the buttons seem not work properly. If I want to rest, it will not activate when pressed.
Hi
Daniel
Aug 29, 2011 | Dishwashers
Not filling with water. After a wash cycle, I noticed that the detergent door had opened but half the detergent was still in the door and the other half had fallen onto the utensil rack. I tried running a...
Hi
You'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 12, 2011 | Viking 24 in. Professional Series VUD141...
Dishwsher doesn't get disher clean
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Hoover 24 in. DT999 Free-Standing...
My GE Dishwasher model GSD1300N10WW doesn't clean dishes,glasses and silverware. Everything has a film on it. I think the tower sprayer might not be popping up but cannot tell.water does spray from the...
Hi
Daniel
Aug 04, 2011 | Maytag Dishwasher
ESL624 dishwasher. On any cycle the machine stops after about a minute or 2. Its as if it cuts out for some reason, It pumps out but it doesn't get to the point where it starts letting water in....
Hi
Daniel
Jun 28, 2011 | Electrolux 23 in. ESL624 Built-in...
Dishwasher runs but gets no water...
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Jan 31, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
No water going in unit. was working fine for last 7 years
Hi
Daniel
Dec 11, 2010 | Viking 24 in. Professional Series VUD141...
Will not fill and will not run even when filled by hand.Is it the circuit board?All fuses and switches are good.
Hi
When the Dishwasher is not filling in, you’ll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don’t get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Daniel
Aug 26, 2010 | Hobart Dishwashers
GE 24 in. GLD5500L Built-in Dishwasher Logo
124 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
