Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Hi I have a cabrio washer wtw6600sb1..... The f1 message keeps popping up and it keeps shuting down on me ... I read that this is In the control board so I need to know what I can do to fix this problem I also read that there were a recall on this same washer... If you could help me and let me know if u can send me something or come to fix it I would appreciate it.... Thanks Brandy Stokley
  • 15,935 Answers
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^$#@
Posted on Sep 21, 2010
The f1 code pops up
Hello
F1 error with your whirlpool cabrio is a common issue with these types of washers. This error indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known issue for them. Please get back to me if you have any other questions.
Kevin
Nov 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 ERROR MESSAGE ON CABRIO. I STOP THEN START AND ALL IS OK. BUT, TO AVOID THIS, WHAT PART DO I NEED TO FIX THE PROBLEM, SOMEWHERE I READ SOMETHING ABOUT A PART IN THE LOWER REAR PORTION OF THE WASHER?
Hi
F1 error which is a common issue with Cabrio washers indicates primary control failure and manufacturer is aware of it. To resolve this issue I'll recommend you to contact Whirlpool at 800-253-1301 so that they can replace the parts without any charges. Please let me know if you need more help.
Thanks Rylee
Oct 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer keeps shutting off and F1 shows up on the display.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 12, 2010 | Kenmore Oasis 27042 Top Load Washer
F1 error
Thank you !!
Jul 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
How to fix my Whirlpool Cabrio washing machine F1 code that keeps popping up whenever I turn on the washing machine.
Hello, error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. To remove and replace the control you’ll have to unplug the washer and then remove three screws from the rear of the console assembly. Pull console towards front of washer to hinge open and/or remove console. Then remove the one screw holding the machine/motor control assembly to the console tray and two plastic legs on the rear of the machine/motor control assembly that fit into the console tray.
Thanks
Jun 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600sb1 has a f1 code what's the problem?
The control board is shot. Whirlpool did a recall on those boards, so get in touch with them and see if your machine is covered. If it is, whirlpool will cover the parts and labor for free.
Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting the "F 1" error message when i start a load, what should i do
The F1 error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I beleive Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Nov 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer Error message code F1
f1 code means the main control needs to be replaced. pretty common repair
Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
178 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
