Question about HP Pavilion zv5120us (DZ329UABA) PC Notebook
Springs for screen cover are broken. Cover has to be blocked to a viewing position. Need instructions on removing to determine if springs are broken or connecter is loose.
  • 3,083 Answers
This site has some good articles on HP repair, and should help you figure this out:
http://www.insidemylaptop.com/remove-lcd-screen-replace-backlight-bulb-hp-pavilion-zv5000-laptop/
Here is the page for the hinge replacement, although they're using an Acer in the video, but it should show the process:
http://www.insidemylaptop.com/category/display-hinges/
Here is a website for parts:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=408443
Just take your time, be careful, and you should be able to get it back in operation.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 10, 2010
Victory motorcycle won't shift and the transmission just revs up but won't shift or move, the clutch won't put bike in gear to move
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Shifting Problem
Shifting issues
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=13620&start=1
Victory Motorcycle Tranny Cover Disassembly Shifter replacement
Witchdoctor How to adjust clutch cable on Victory motorcycle
Jun 18, 2017 | Victory Motorcycles
Ge washer wjrr4170g agitating very hard and rough and out of balance but is level on the floor. What is possibly wrong?
Hello Trina;
My name is Peter. I am a retired field service appliance technician.
Go into Searspartsdirect.com. In put your model number. Ther will be a diagram showing your rod springs. I suspect you have a bad rod spring or it has come loose. The rod spring stabilizes the washer drum during agitation and spin cycle. These are relatively inexpensive parts approximately $16.00 each.
Lets repair this together. I have faith in you Trina. No man required.
Unplug or turn the circuit breaker off.
To replace this part you need to open the top cover. There are two retaining clips, one on the right and one on the left. If you look into where the top cover meets the front plate you will see these clips. With a putty knife or a spatula push on these clips to release the top cover. Raise the cover up.
Now, you need to remove the front cover. First disconnect the electrical connector to the door latch. Using a small screw driver wedge between the connector for release.
You will see screw on the inside at the top of the front cover. One on each side. They are either Phillips head screws of hex head screws. Remove these fasteners. Lift up on the front cover. There are tabs that go into slots. You may have to play with the position of tabs and slot to remove. You will now have access to the rod springs.
If the rod springs are loose tighten the threaded fasteners. If they are broken replace. You probably have only one broken. Keep running the dishwasher then you will have both broken.
Peter, Baltimore, MD
Nov 09, 2014 | Washing Machines
Loose Handel that engages the blade. Took steering wheel off and cover and it's not moving any springs.
You have to remove the cover and check to see if the spring end has broken. This happens after awhile due to friction on the engagement spring. You can re-bend the spring into a half circle then reconnect. If this gives you trouble then replace with new spring. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Apr 26, 2014 | John Deere L100 Series
Kodak slide projector flap block the slide fron viewing
The spring that tensions the shutter is either unhooked or broken. The spring is located on the outboard side of the slide gate - - & is positioned vertical. Without this spring in place & functioning, the shutter will cover part or all of the projected image path.
Nov 13, 2012 | Kodak Office Equipment & Supplies
Wash machine shakes and bounces when operating with a full load.
you need to remove the control panel and 2 clips that hold the entire cover on then tilt cover toward you to remove outer cover then check the tub springs 3 of them if one broken it will be loose and bounce,also the drive block could be worn under the inner tub,the shipping straps or bolts need to be removed if the machine is new otherwise it will also bounce around
Jan 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
How do u remove the cover to change the bulbs on panasonic whisper-fit low-pro?
The cover is gently pulled down.
It only comes down so far, as it's held up by springs.
There are four springs. Two on each side. To gain more clearance on one side to replace the bulb/s, you disconnect the end of two springs on one side.
After the bulb/s are changed out, reconnect the springs, ease the cover back into position.
Oct 01, 2009 | Panasonic WhisperFit-Lite Low Profile...
Replace broken door springs F&P dw918td
To replace the door springs, you need to remove both the side covers. This can be done by first removing the lid and then working your way around both panels until they come off. You will then see on either side a cord that is attached to a single spring.routed on a small bend. Very unlikely the spring is broken but possibly the cord has or it has pulled loose from its position. Rectify then reassemble.
Sep 27, 2009 | Dishwashers
Installing klutch
Buy clutch cover gasket
Unhook clutch cable at clutch cover
Remove clutch cover
Remove 5 clutch spring bolts
Remove springs
Remove pressure plate
Remove plates and disc noticing order
Replace with new plates/disc in same order (after soaking in oil for at least a few hours, over night would be better.
Put everthing back together in order of removal.
May 03, 2009 | 1997 kawasaki VN 800 A Vulcan
My husky is an automatic and it does not shift into drive anymore
You may have broken a clutch spring. Husky automatics use 3 springs for each of the 3 gears. Each spring controls a clutch shoe. A broken spring would prevent you from engaging a gear and causes other mischief inside the case. You should remove the left case cover and inspect. Halls Husqvarna has parts catalogs for almost every year. Thumpertalk.com has a discussion thread on this problem.
Mar 23, 2009 | 1989 Husqvarna AE 430
Right-click button has collapst on bottom side. have to click at top of button
To disable Aspire 5100.
1. remove battery, harddrive.
2. open all cover on the back of laptop.
3. removed wireless antena cable from wireless card.
4. remove power cover (power cover is cover that have power button)
5. removed 2 screws on the back that hold lcd.
6. removed 4 screws that hold lcd. (now you can remove lcd).
7. remove 2 screws on top that hold uppercase from lowercase.
8. remove all screw on the back.
9. remove heat sink, and remove 1 screw under heat sink.
10. that's all, you can remove uppercase and repair it.
i hope this help you. good luck
Mar 22, 2008 | Acer Aspire 5100 Notebook
HP Pavilion zv5120us (DZ329UABA) PC Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
