Question about Niko OTP-2011R 20 in. LCD EDTV
Hello: My NIKO TV's Power supply has burnt out. The Tv itself is ok. How may I purchase another Power supply, ASAP? 15 V-4.2 A Max 63 W Thanks for your time and efforts. Mike Faria, North Carolina.
chie-chie
  • 98 Answers
SOURCE: Need Power Supply
usually Lcd tv rated 12volts 3 ampers
but be careful.. check the polarity of ur lcd before plugging it.... some power supply has different polarity. good luck..
Posted on Feb 12, 2008
  • 3 Answers
SOURCE: remote control codes
That is what I'm talking about, not even Niko knows of a code. That is why I had to buy a learning remote like the Sony RM-AX1400.
Posted on Apr 07, 2008
SOURCE: Niko 32" TV no screen
Inverter card.
p/n vit70002.00
Approx $180
The inverter card drives your cold cathode lighting.
If you pull the covers you will find all the lights out, if any of the eight legs of the inverter go out (driver transistor) the card will not work.
Howard
Posted on Aug 12, 2008
SOURCE: NIKO 32 in
I have ordered the owners manual for the Niko OTP3211W.
I'll let you know what happens when it arrives.
Posted on Jan 01, 2009
  • 1779 Answers
SOURCE: where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Posted on Feb 06, 2009
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
TV does not turn on just an orange light for power. Is there a fuse? Is it shot? Thanks! Doug
hi ;
your LCD TV has a fuse, but you said it has orange light.
maybe there's problem with power supply
try some basic troubleshooting
you have to remove back cover ,then check power supply section, some power supply has
built with inverter board that supply the bulb of LCD.
check for bloated capacitor ,you can do some soldering by removing capacitor. try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV.
if this procedure wont help, maybe some parts has a failure. make some comment so i can help you more further.
thanks ,, hope this help........
Sep 14, 2011 | Niko OTP-3211W 32 in. LCD Television
Nec nlt-19hdb3 lcd tv turns on, boots ok, then powers itself off after about 15 secs
Power supply board have problems.Tries unplug,replug the tv an hour later,the tv now,will reset itself back to factory setting.The tv should work now,not than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 11, 2010 | NEC ONYX NLT-19HDB3 19 in. LCD TV
Will not work at all
check for the power supply is locater at the back of the tv..you need to open the cover.the output power of the the power supply is 5vdc for the cpu and 12v-24dc for the backlights..visually inspect the components of the power supply.replace any burned capacitors and resistors..replace the secondary fuse with the same ratings..
May 17, 2010 | Niko SV3206 32 in. LCD Television
TV turns itself off, and then switches back on with no display
Its normal for the 'brick' (power supply) to get hot, the power supply would not be the problem here as if it was faulty it wouldt power the screen at all, I guess you have a small 15" LCD TV which runs on 12V? The problem would be internal, Hitachi TVs have this problem, its normally down to a small capicitor on the main board. Speak the manufacturer for more info.
Sep 13, 2009 | Westinghouse LTV-19W3 19 in. LCD...
Akai TV with Megmeet power supply
Hi artoo
if you want you can fix the power supply. i know service tech who fixed my tv power supply. His email is jah2mil@hotmail.com.
Apr 10, 2008 | Akai LCT3201AD 32 in. LCD Television
Need Power Supply
Feb 12, 2008 | Niko OTP-2011R 20 in. LCD EDTV
I turned it off, now it won't turn on.
I turned it off, now it won't turn on. Sir this problem is mostly due to power supply. as when ever you switch on the set due to in rush current components of power supply may go defective. regards thanks
Sep 11, 2007 | Sylvania 6432GG 32" TV
Loewe Aconda 9381 HD/DR+ Will not switch
Could be loss of voltage on secondary or problem on Power supply. Check 4/5 (depnding on chassis) wickman fuses on secondary if none are o/c then replace power supply components with Kit from Loewe. Part number 90415.900.
Should take tv engineer about 1 hour (max) to replace parts form kit.
Aug 08, 2007 | Loewe ARC332 32" TV
TV making chirping sound
If one of the secondary supplies is shorted, the power supply will "chirp" when plugged in. This is the power supply's way of protecting itself and this usually happens when the horizontal output transistor is shorted. If this set was in my shop and needed a new output transistor, a fair price would be right around $100.
Jun 28, 2007 | Toshiba 32DF46 32" TV
Niko OTP-2011R 20 in. LCD EDTV Logo
95 people viewed this question
Top Niko Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
noel
noel
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
