Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I replaced the fixing unit (never did it before) and now I get service code F-35-10. Did I blow it up?
  • 1,110 Answers
What make and model of copier do you have? The F35-10 code does not belong to the Minolta Bizhub 350 under which your question is posted. At least I have never seen it and it is in not in my factory service manual.
Posted on Sep 10, 2010
How do we fix this error on Fisher&packel CPAP?
Error codes 5.0 to 5.8 indicates a problem with the motor.
Try removing the unit from the power outlet and then plug back in.
If error code persists technical manual recommends returning unit as motor problem.
http://www.vivisol.nl/assets/uploads/services/ICON_.pdf
my take on it !
also check the little filter at the back of the unit and blow the dust out of it. You will be surprised how much dust is filtered out by this filter. .
NEVER move the unit without emptying the water out of humidifier first !!!!
Jan 24, 2017 | Washing Machines
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
Error code e000 0000
If Error code is E000 then may be major cause:
+ The thermistor has an open circuit or short curcuit
+ The heater has an open circut. The thermal fuse has blown
+ The power supply PCB has a fault
+ The engine controller PCB has a fault
To Fix Error code E000 of Canon LassetJet LBP-3300 printer, you can try the following:
+ Check connector of the fixing film unit
+ Replace the fixing film unit
+ Replace the power supply PCB
+ Replace the engine controller PCB
This is not a job for a novice. Get a service technician to service the unit.
Apr 23, 2014 | Canon LBP3300
Canon Ir2318 error code 00003
the code is related to the fuser section.If the machine is new then enter the service mode by pressing additional function and then * and clear it in error clear , if it is old machine then check the fuser for open thermistor,broken element .
Aug 24, 2011 | Canon imageRUNNER 2200
Fixing unit error. Turn off and unplug the printer, and then contact the store where you purchased the printer or your service representative. When contacting the service representative, inform them of...
The problem is in your fixing unit
the reasons may be
(i)The thermistor has an open circuit or a short circuit.
(ii) he heater has an open circuit.The thermal fuse has blown.
(iii)The power supply PCB has a fault.
(iv)The engine controller PCB has a fault.
Check the following,
- Check the connector of the fixing film unit.If found no problems,
-Replace the fixing film unit.Not solved?
- Replace the power supply PCB.Still having problem?
- Replace the engine controller PCB.
and that's it
Apr 16, 2011 | Canon LASER SHOT LBP-2900 Printer
GE JES1855 1100 Watts Microwave Oven not working. Display lights do not come on. Checked wall plug and it is ok.
Sounds like internal fault protection fuse blew. can be fixed by qualified technicians. their is very high voltage coils and capacitors within this unit and can cause harm or death instantly if not discharged properly.
Aug 12, 2010 | GE JES1855 Microwave Oven
Copier 3300 showing error code E000002-0000
E002 is fixing related error, try in service mode * 2 8 * copier, function, clear, under err - clear error then turn off and on if ok, be sure that you have enough air flow around the copier, no air condition blowing in or near by copier, maybe eaven raise the temperature of fixing unit ( if you want to do that send a message ),...
If does not helps replace fixing film unit
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Sharp 10000 BTU 38db portable air conditioner blows cold air for 2 minutes then blows warm air for 5 minutes then turns off for 20 minutes then repeats this process. How can I fix this problem to blowing...
sounds like the unit has a low charge and is cutting out on a low press safety. This is more then likey not something you can fit yourself most of this units are not really serviceable with out cutting the lines open and adding a valve. If the unit is still somewhat new you can try for a warranty repair, if not you are better off to replace it.
Aug 30, 2009 | Heating & Cooling
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
168 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
