Question about Numark Audio Players & Recorders
My cd's arent reading at all!!...axis 9....changed the lens and still nothing.
4 Suggested Answers
SOURCE: no x and y axis!
Hit [2nd] [ZOOM] and make sure "AxesOn" is selected
Posted on Jan 28, 2008
SOURCE: How come my axis 9 cd players pitch control moves on its own?
i take it u know to press key when changing the tempo? if u press key it changes the tempo but keeps the pitch the same. i keep that on all the time. if i want to change the pick i hold key and press either + or -
Posted on Sep 03, 2009
  • 17 Answers
SOURCE: I have a 'Numark Axis 9' DJ standard CD player.
You will most likely need to replace the CD drive. I believe the OEM part is CM-H90. Only 8 screws to complete this task.
Posted on May 05, 2010
Want to connect my nu mark axis 9 to my computer by using virtual dj
Hi gregory_fils,
Please read the manual which came with your nu mark axis 9 to see if it is compatible with your computer if so, there should be instructions in the manual.
i hope this helps.
Mar 27, 2011 | Nu Mark Numark Axis9 Table Top CD Player...
My axis 9 wont play burnt cds
I'm having the same problem with the Axis 9 I just purchased on eBay. And so is the person who posted "Numark Axis 9's. . Problematic. Ahhhh!!!" Seems ridiculous that this would be so common. I definitely don't want to re-burn 100's of CDs just to use this CD player.
Nov 08, 2009 | Nu Mark AXIS 9
CD Has a hard time loading. Staticy sound and skips
This is a sign that the optics are dirty of out of alignment. The static noise comes from digital dropout or a problem with the D/A converter IC. Try cleaning the lens first using a cotton swab and alcohol. If that fails to resolve the problem, update this and confirm you rmodel number. I will then check for the cost of replacement optics and D/A converters.
Dan
Oct 21, 2009 | Nu Mark AXIS 9
Numark Axis 8 Problem, does not recognize any CDs
if you are not a tech.have one look at your set.change your lens.or the wire ribon that is attached to the body of the lens that leads to the pc board.if that does not work your micro chip is damage replace the pc board.they cannot be repaired as they are duble solder unless you have equipment to do repair on them.good luck.
Apr 10, 2009 | Nu Mark AXIS 9
Numark Axis 8-Screen says CLOSE, but does not recognize CD
either your set does not recognize the cd or your lens need to be replaced the age of your set has lot to play if it is old satrt shopping for a new set.anyhow have a tech look at your set.a look on the wire ribonthat leads from the body of the lens the pc board will not hurt probably it is damage.good luck.
Apr 10, 2009 | Nu Mark Numark Axis9 Table Top CD Player -...
Mar 22, 2009 | Nu Mark Numark Axis9 Table Top CD Player...
Skipping
i have the same problem there but i no how to solve it....
its not hard just go any buy new good quality cds i found that sony work very well with the axis 9s and when your making new cds from widows media player just turn the burn speed down to med speed an best quality you do this by going on the littel drop down menu underneath burn go to more options then it will say burn speed change to med go onto the bottem slider and put that in the middel an it works like a dream
Feb 09, 2008 | Nu Mark AXIS 9
Axis 8
try cleaning the lense using a lense cleaner and/or burn your cds at slower speeds. 16x and lower work best
Feb 08, 2008 | Nu Mark AXIS 9
Nu Mark AXIS 9 Problem
u are probably using scratch mode 2, hold prog and scratch to change between different scratch mode, if this doesnt work, i recommend u take your jog wheel for cleaning
Nov 07, 2007 | Nu Mark AXIS 9
18 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
