Question about Alpine Car Audio & Video
I have an alpine cda 9856 and I'm trying to hook my Droid Eris up to it to play music from the phone using a drive and play connection.
5 Suggested Answers
SOURCE: radio sound but NO cd or ipod sound
its not the radio. you have an amplified system in your vehicle and you hooked up the power antenna (blue wire from the radio) and the amp is only energized during AM/FM playback. disconnect the blue wire and connect the blue/white to the car's harness to energize the amp during ipod and cd playback
Posted on May 26, 2008
SOURCE: Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Posted on Nov 06, 2008
thepot
  • 188 Answers
SOURCE: Alpine CDA-9856 interrupt message
theres a wire loose, bring your car to an audio tech and he'l sort it
Posted on Nov 09, 2009
  • 166 Answers
SOURCE: what is the color code for sub woofer control
Well I found out on Pages 34 & 35 of the following Alpine manual:
http://vault.alpine-usa.com/products/documents/OM%20CDA-9856.PDF
The Remote / Amplifier Turn On is a Blue/White wire.
Posted on May 15, 2010
Iphone mode
For most alpine unit there is a separate unit to control the iPhone and is very easy is just a plug and play connection. Find a compatible unit for your deck.
Nov 07, 2013 | Alpine CDA-9856 CD Player
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
Jan 15, 2013 | Alpine CDA-9856 CD Player
What is the color code for sub woofer control on alpine cda-9856 wiring?
May 15, 2010 | Alpine CDA-9856 CD Player
Nov 06, 2009 | Alpine CDA-9883 CD Player
Problems with amp or stereo
check out www.installer.com
this site has your stereo's wire diagram.
The amp wires only go to the rear output (rca jacks on back of cd player)
It wont work right if it is connected to the front outputs on the back of cd player
Jan 16, 2009 | Alpine CDA-9856 CD Player
CD changer will not mix discs randomly
RANDOM PLAY SHUFFLE M.I.X (has a little folder next to the mix sign. (#5 button) NOT #6
SHUFFLES ALBLUMS AND SONGS
This option randomly shuffles the next disc and songs
More info here if you need it:
http://www.retrevo.com/support/Alpine-CDA-9856-Receivers-manual/id/1060dj492/t/2/
Sep 03, 2008 | Alpine CDA-9856 CD Player
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Aug 20, 2008 | Alpine CDA-9856 CD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Sound Issues
The player has a built in safety device which only allows it to turn up so high. It help to avoid burning out your equip ment. Best way is to put sound on one device 3/4 ways up and then use the other device for adjusting the volume from there.
For sound in one channel; either there is a wire unplugged or not getting a good contact, or the player is set for mono instead of stereo
Jan 22, 2008 | Alpine CDA-9856 CD Player
Alpine CDA-9856. Search button for IPod will not bring up menu
I have the same problem with a CDE-9870R and my iPod. I tried my daughter's iPod, and it works. I did not search any further, but it may come from the iPod software version. Mine is more up-to-date than hers (5th generation iPod 1.1.2 2006-06-28 update).
Mar 26, 2007 | Alpine CDA-9856 CD Player
Car Audio & Video Logo
100 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
