Question about Konka K2788U 27" TV
I have a Konka K2788U. The connection for the coaxial cable sticking out of the back of the TV has broken off. Is this a simple fix for a repair shop or is it expensive in parts and labor? Can I purchase the part on my own and fix it?
  • karenj780 Sep 09, 2010
    How much should this fix cost at a reapair shop
    Guru:
  • 374 Answers
Hello
To know how much it will cost to replace exactly. It can be somewhat easy to fix but in most cases you would need a soldering iron and some solder.
To fix it yourself you would need to read up on how to do it with safety. It can be very dangerous because even when the tv is off and unplugged in the "CRT" TV's they still hold a charge even weeks after. I can get you some instructions and some safety dos and donts if you go this route.
To have a tech fix it can be pricey. I would call around your area to see if there is someone that would do it for a decent price. You may even find a few places on this site in your area.
Let me know either way but please read everything and double check if you want to open the TV.
Safety first!
Posted on Sep 10, 2010
  • Robert Dahmen
    Robert Dahmen Sep 10, 2010
    I forgot to add that your should check radio shack if you have one close to you for a female "F" connector.
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
Jan 05, 2011 | Dual Presidian DVD Recorder
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
The attachment point for the coax cable was pulled off-broken off
You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
Dec 03, 2009 | Sharp 27H-S60 TV
The coaxle broke where you put the cable line on
The coaxial connects inside the set to the tuner. It needs to be resoldered in to the board & secured on the outside to the tuner. Its a quick fix at any tv repair shop. Unless u tried stick something inside & damaged internals of tuner
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken coax connection on back of unit
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken coaxial
All you need is:
1 - coaxial coupler
2 - small wire nuts
electrical tape
Nov 10, 2008 | Samsung LNT4066F 40 in. LCD Television
Coaxial output broken
If the connector end is not damaged and the tuner circuit board is not broken, you can solder this back onto tuner, and solder the end back on the circuit board. You should take the tuner out to do this proceedure. A TV shop usually charges $50.00 to do this.
Oct 24, 2008 | Sanyo DS20930 20" TV
Connecting a samsung dvd-vr to TV with cable & rf modulator
my coaxial cable hook up is broken from the plasma. Can i fix it?
Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Coaxial input jack on the TV broken off so I cannot connect my coaxial cable from wall
All you need is:
1 - coaxial coupler
2 - small wire nuts
electrical tape
Sep 18, 2006 | RCA D52W19 52" Rear Projection Television
Konka K2788U 27" TV Logo
Top Konka Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
