Question about Xerox Phaser 6180N Laser Printer
My Phaser 6180MFP makes a horrible squeaking sound. It does it during printing and during calibration. It is a very high pitch squeaking that commences with the print engine start. It does not seem to be the paper pick up mechanism.
4 Suggested Answers
SOURCE: Xerox Phaser 6180MFP i have replaced toners
Supposedly the 6180MFP allows the user to select a non-genuine mode (select "Non-Xerox Toner" on the maintenance menu). This option is listed on page 9-18 of the User Guide, and I think it's the same as the Non-Genuine mode described on page 1-38 of the Service Manual. However, when I actually look for this option on my printer it doesn't appear to be present. Maybe Xerox removed it and didn't update the documentation? Anyone else know about this setting?
Posted on May 11, 2010
  • 92 Answers
SOURCE: Phaser 6180MFP has error code
Hi, the error code you mention suggests you are able to print a start page but still the error is constantly displayed on the device.
This error is related to a failure on the Fax module, originated by a possible corrupted job on the device memory.
3 Ways to solve this.
  1. Unplug the device from the power cord and leave it for around 10 minutes. Then plug the power cord back on. This will allow the memory to clean.
  2. Clean the memory. Before you do that print a configuration report to ensure you keep all configuration data, such as network information. On the front panel navigate to System > Admin Menu >Maintenance > Initialize NVM. Be aware this procedure might erase your network configuration. therefore is important to print the configuration report previously
  3. The same steps taken in Step2 will be required but done on a Diagnostic menu. For this I would advise you to contact Xerox to get an onsite visit.
Hope this helps. Regards,
Posted on Oct 04, 2010
  • 304 Answers
SOURCE: I have error on my
116-324: Controller Error (Illegal Exception)
To access Service Mode, press Up and Down Arrows at power ON.
Go to EEPROM Test
EEPROM Test
? Start
? Processing
? Check OK
Performs write/read/verification of the test patterns (0xff, 0xaa, 0x55, and 0x00) on one byte at every 0x400 from the first address of EEPROM.
Posted on Sep 14, 2011
Fax confirmation sheet on a Xerox Phaser 6180MFP
Not quite sure what you mean here, it can be switched either on or off within the internal settings. Normally the default would be off in a large office due to wasted pages, but in "print for pay" a customer has a receipt that the fax had arrived at it's destination.
Good luck.
Jun 13, 2014 | Xerox Phaser 6180N Laser Printer
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
My dryer makes a horrible high pitch squeaking sound when it is in the dry cycle. It is about 11 years old. GE profile front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 05, 2011 | GE Dryers
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
Xerox Phaser 4510 - While printing it makes a squeaking noise
One of two things. The fuser bearings get noisy in those.
Or there are several small hard plastic rollers on steel shafts or even mounted on springs they they can get very noisy.
Feb 24, 2010 | Xerox Phaser 4500/YDX Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
High pitched whining
Sounds like a tube TV . If so I believe the tube is cracked not hard to do during moving Ive done it before. it can be replaced for around 125$ to 200$ look at how much your TV is worth and if it does not exceed the value of you unit . Then locate a repair shop in the yellow pages.
Oct 05, 2008 | Computers & Internet
Squeaking
Mineral oil! It worked very well but it took a lot.
Jul 11, 2008 | Achiever CCS5000 Shredder
Xerox Phaser 6180N Laser Printer Logo
275 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
