My Kenmoore washer frontloader turns on, starts to shoot water out, seems fine for a little while, next thing you know it starts beeping F6 and drains the water out. I clear and restart and its the same story all over again. How can I fix this.
  • 1,531 Answers
This is a motor control error code.you need to check the resistance on the motor if they read infinite then replace the motor.
make sure to check all the wiring to see if it is all connected properly. the main control board may also need to be replaced.
If there is no motor operation at all then change out the motor. if there is some motor operation then change the main control board
Posted on Sep 09, 2010
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Nov 11, 2009 | LG WM2277H Front Load Washer
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
Kenmore HE3,what F6 means
f6 is a communication error with the motor control board, i would unplug unit , remv eth bottom panel)3 screws across the botom of nit) andthe motor control board is rightthere on the left floor of the unit. check for good non corroded terminal connections, ive also seen extreme humidity/ water in surronding area trip this code
Jan 26, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet 9200 Washer door lock issue
no thiis is normal operation, it is considered a child safety feature. in case a sleeping child should happen to be in machine, the short 2 sec blast of cold water will wake them and give them a chance to exit before the machine starts washing.. all whirlpool frontloaders do this, thats how it waas explained to us at factory training.
Dec 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Apr 18, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
