Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Alert F1 when starting wash cycle - Whirlpool Cabrio WTW6600SBT Top Load Washer
    President:
  • 1,932 Answers
F1 = Primary Control Failure
F then 1 flashes when there is a primary control failure. Replace the machine control assembly
Thank You
Posted on Sep 10, 2010
F1 and beeping
F1 means the drawer lid is not closing properly - (lid seal leaking) which caused water to splash out when you started the wash cycle. The flood circuit on base of dishwasher housing (under the bottom drawer) has tripped. You will have to find the source of leakage and also dry the base of dishwasher housing. Make sure the dishwasher is unplugged form mains socket when you work in it.
Jan 16, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore Elite Washer Oasis Model: 11027042603 I have been getting a F1 code error with all wash cycles for the past month. It occurs as soon as I start the wash cycle and with 23 minutes remaining in the...
depending on its age take a look at the motors brushes. sounds like 23 mins would be spin cycle when the motor picks up speed. they may need replacing.
Dec 08, 2013 | Washing Machines
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
I get error F1 every time I start and before the rinse cycle. I will change cycles, change settings within cycle menus, it tales at least three attempts of shutting it off and restarting it. Now it will...
here's the part # W10189966. I guess whirlpool had a recall on the units and revised the control boards. might want to call whirlpool on that. Good luck :)
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 Alarm @ rinse cycle
F1 code = Primary Control Failure. Replace the machine/motor control assembly. If you use a screw driver in front of the machine to open the top you will find a repair manual on the inside of the front panel. or depending on the model, you can even unscrew the bottom and find the manual.The manual inside is actually meant for technicians.It contains the error codes and instructions related to them.will be looking forward for your comments if there is any further problem in this.
Dec 15, 2008 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
