Question about Daewoo FR-064R Refrigerator With Ice Box
WHERE SHOULD TEMPERATURE CONTROL BE SET ON DAEWOO BAR FRIDGE? IS SETTING 1 THE COLDEST OR WARMEST?
GE Profile Brita Fridge. Have setting down as low as possible and crisper foods continue to freeze. How can I fix that?
You need an internal digital thermometer to see if 1 is the coldest or the hottest. If you turn it to 6 and the temperature remains the same, the thermostat is faulty.
If 1 is the warmest and it continues to freeze crisper foods like lettuce, you need a new thermostat. Your ideal temperature is between 3 and 4' Centigrade at the coldest part, usually above the bottom shelf.
Aug 23, 2016 | GE Refrigerators
My LEC T5029W is set to 1 however food in refrigerator is frozen -10 degrees C?
one is the coldest setting
set it higher say about 1/2 the adjustment of the knob
Aug 03, 2016 | LEC Refrigerators
Just got delivered a new kenmore french door fridge and temp. on freezer is zero. it doesn,t say what temp to put it on
Usually 0 is the warmest setting 1,2,3,4,5 would be increasing to coldest level with 5 as coldest
Jan 04, 2015 | Kenmore Refrigerators
How do i set my temperature on my fridge freezer its a aeg santo ?
Hi
The santo was originally built with a standard thermostat, this is graduated from 1 to 6 where 1 is the warmest setting and 6 is the coldest, normally you would set this to btween 3 and 4 and adjust it slightly to your favourite.
Regards
Gordon
Apr 20, 2011 | Refrigerators
A block of ice forms on inside on the back of the fridge,temperature gauge set at 5,do i have correct temperature setting,cheers stuart.
1 is the warmest 5 the coldest,so you are overcooling your veg etc,use a fridge thermometer and run it at +5c.this is the most economical setting,and will keep your lettuce fresh not frozen.
Nov 25, 2010 | Whirlpool Refrigerators
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Dial goes from 1 to 5 in fridge, what is correct setting
1 is warmest and 5 is coldest. set to 3 and just see if that gives you a reasonable temperature. fridge temp should be about +4degC and freezer temp about -18degC
Sep 05, 2008 | Refrigerators
Indesit fridge freezer.
lower the number, warmer the fridge.
setting 1 - warmest
setting 5 - coldest
this is the same for all fridges
Jun 29, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Daewoo FR-064R Refrigerator With Ice Box Logo
1,242 people viewed this question
Top Daewoo Refrigerators Experts
John Tripp
John Tripp
Jerry Greenberg
Jerry Greenberg
noel
noel
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
