Question about Samsung SyncMaster 2233SW Monitor
Picture goes off after 1 second on power - diagnosed as an inverter fault.Please advise where we can purchase.Thank you.
  • 732 Answers
Service341, Open unit first!! Look for typical bad capacitors on SMPS power supply board!!! Document unit "tear-down" using video camera or digital still pic's so you can perform "reassembly" of unit after repair is successful. Have you been to YOUTUBE so you will know what to do BEFORE you do the repair? Watch some videos first. Have you heard the old saying, "a picture (or in your case) a video clip is worth a thousand words!!! You can do additional comment here after you do your research at YOUTUBE as to the worth of this response. Possible you only need $5 in new capacitors and not a $45 SMPS/inverter board. Get back to us and report on the brand name of the filter capacitors you find populating the SMPS printed circuit board. I hope you don't find any "CapXon" brand filter caps on your board!!! 12fixlouie
Posted on Sep 10, 2010
When powering on my Samsung 55 inches LED TV, the middle/bottom light panel just flash/blink and there is no picture on the TV screen dark/black screen. I would have to let the TV on for 1-2 hours to
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 06, 2015 | Samsung Televison & Video
Grundig LCD TV
try to resolder the pins of the chroma IC and some possible lose connections you can see in the PCB board...
Aug 01, 2008 | Televison & Video
V is not working. when we press standby button to switch on 1 second on and have sound not have picture and go to off
It sounds to be a main power regulator board fault. Chekc and replace it. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 08, 2013 | Sony KLV32S550A 32 LCD TV
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
When I turn my TV on there is sound, but, the picture vanishes after a couple of seconds. Why?
The backlight inverter is what powers the screen to "light up." You will need to check your power supply for the proper voltages going to the backlight inverter. If those all check out ok, then you need to replace your inverter to get your image back. You can find a new inverter by searching "inverter + model number of your tv.
Please rate if this helped :)
Apr 04, 2011 | LG Televison & Video
I have a sanyo model #dp42848 and when i turn it on the picture comes on for a few seconds then you hear a noise the the picture goes out. The sounds still works. What could this be and how much will it...
Hi art_davis,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason was the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Check the parts here.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Apr 02, 2011 | Sanyo DP42848 LCD TV
HIT REMOTE TO ON POSITION GET NO PICTURE BUT VOLUME GOES ON
Hi rallyred71,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
Hope I helped you.
Have a nice day!
Mar 24, 2011 | Televison & Video
My Westinghouse SK-32H540S pictures shuts off after 10 seconds. the sound stays on but no picture. is it the troubleshoot? i tried unpluging everything and repluging it and still the same thing happens...
This problems are the tv 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards provide the tv LCD screen pannel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Hello, When I turn on my TV the screen does not come on but I hear sound. Can you please advise me on what I should do? Thank you in advance.
Hi tlc19732001,
1. Power supply - missing 24vdc coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the 24vdc is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
Hope I helped you.
Have a nice day!
Mar 10, 2011 | Samsung PN50A550 50 in. Plasma TV
Shows picture for a second when i press button than goes dark
Issues with back light:
Please do not attempt to diagnose if no competent.
Do at your own risk.
Check for 24 Volts power to the inverter board
No Power---Check Power Supply
Power Present---
Verify status voltage 3v to 5v on inverter board harness (plug)
Replace Inverter Board
Feb 11, 2010 | Tatung V30DMTT 29.6 in. LCD Television
Samsung SyncMaster 2233SW Monitor Logo
453 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
