Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
I'm looking for a replacement antenna for the IM600. The original snapped in the middle.
I had the same problem, email altec Lansing and they will send you one out. It took a few weeks but I got one.
Posted on Sep 16, 2010
I am trying to put an extended NNTN5539A antenna on my i355 phone, but I can't figure out how to remove the original antenna. I saw on one forum where someone said there was a tool to remove it, then I...
It's simple. In order to install the antenna, you must do the following:
Using a very small "star" type screwdriver, remove three screws from the base of the unit. Remove the base trim piece. The body of the phone is in two pieces (front and back). Use a knife to separate the pieces by first GENTLY lifting the locking tabs on the bottom of the unit so that they will easily unsnap by themselves, just lift them a little bit, not all the way. Insert the blade along the side of the seam and pry gently.
Slowly remove the back. There will be adhesive tape at the top piece, so work slowly. Notice the locking tabs on the sides, they will come apart by themselves, no need to worry about it.
After separating the halves, unscrew the top of the original antenna, screw the new antenna in place, slide the back atenna opening over the new antenna and snap into place, making certain that the side tabs insert properly. Just use your eyes and common sense. Do not force anything, but snapping the halves back together will require a firm force.
Replace the bottom trim piece and three screws, you're done!
Mar 11, 2011 | Cell Phones
Where to find a speaker replacement for InMotion IM600
hi,i have 2 speakers salvage from im600 ozzyris7@hotmail.com
Mar 24, 2010 | Altec Lansing Inmotion-IM600...
Battery part no Mh29654 for iM600 speaker need to purchase a new battery. Proving to be a night mare to obtain as this has 3 wires with sq connecter.Model no McR18650 3.7v
buy a cilyndrical 3.7v battery,a bougth a onu with 3000mah. and use the conectors from your old one,they are built-in circuit take it apart and reuse it
Mar 02, 2010 | Altec Lansing Inmotion-IM600...
I need to replace the Ion Battery for the Altec Lansing IM600
2 screws at the back removed with a cross head screwdriver. Remove the casing, then the battery plugs in to a white connector.
Jan 23, 2010 | Altec Lansing Inmotion-IM600...
Power antenna motor will not shut off
I assume that the power antenna unit is an original equipment unit, if so.
1. Does it run for about a minute then stop? If this is the case, your antenna shaft needs to be replaced. This is a very simple procedure that your local radio install shop can do for you in about 20 minutes.
2. If the motor never shuts off as long as the key is on, you probably have a defective relay on the antenna motor. At this point you need to replace the entire unit. A job that can be a bit pricey because of the price of the unit itself. A cheeper fix is to replace the power antenna with a manually telescopic unit, (no motor), or a fixed unit, (doesn't go down). If you opt for the latter, remember to unscrew or lower the antenna in automatic car washes!
Jul 07, 2009 | 1984 Cadillac Eldorado
Battery in im600 not charging
The battery is probably dead, as it's rated for 400 cycles. When you have the dock's feet out, you can see 2 tiny screws on the back of the unit, unscrew them, remove the hatch and you'll have your battery exposed. 3.7V 1800mAh Li-Ion
Mar 09, 2009 | Altec Lansing Inmotion-IM600...
Remote Control Altec Lansing IM600 - Battery
Turn the remote upside down. At the bottom, there is a slot that opens the battery tray and a series of grooves that are part of a clip that releases the tray. Insert the fingernail of your thumb into the grooves and the fingernail of your index finger into the slot. Ease the grooves (clip) toward the middle of the remote and slide the tray out. There is a ridge in the tray that matches the battery only when the battery is in the proper position. Slide the tray back in. If the remote doesn't work, you've probably inserted the battery in the wrong position.
Dec 31, 2008 | Altec Lansing Inmotion-IM600...
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
520 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
