Question about Xerox Phaser 7750DN Laser Printer
My 7750 thinks i have loaded the wrong paper size when it's the right size. it gives me the error "wrong paper size loaded" opening the drawer and letting it reseat itself doesn't fixt the problem. the only way to get rid of the error is to cancel the job out and start over, and force it to a different tray. The machine only has 4 good trays so i have to cycle them. It gets annoying when you are trying to print 16,000 pieces and they need to stay in order.
    Top Expert:
  • Xerox Master
  • 77,932 Answers
Go into the paper size settings in the menu and re-input the desired paper size.
Posted on Jun 17, 2017
SOURCE: Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Posted on Nov 04, 2007
  • 2072 Answers
SOURCE: xerox Phaser 7750 code 35
Somehow you jarred the fuser. Turn the machine off and reseat the fuser. Open the left side door, there will be 2 thumb screws.
Remove and reseat the fuser, if that doesnt work you have to replace the fuser.
Posted on Apr 05, 2008
  • 237 Answers
SOURCE: I am trying to print
The tray itself should have tabs on the side telling the type of paper look at those and see if there is anything broken off.
Posted on Feb 11, 2009
  • 398 Answers
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
  • 193 Answers
SOURCE: Printer trying to print from the bypass tray
check your software setting OR delete and re install your software
Posted on Dec 03, 2009
Error Code E07
  • Open the drawer the printer is currently pulling from when the error message "E07" appears on the display. Verify that the paper in the drawer is the correct size and close the drawer firmly!
  • Oct 23, 2014 | Copystar CS-1500 Copier
    Phaser 7750 Not Printing, No Error codes, Fuser Wont Warm Up, Wont Detect Open Trays or Doors
    It sounds like one of the cover or tray sensors is not working correctly. Check the actuator on the fuser cover, sometimes these break off so the printer thinks the cover is still open. If that seems ok and you have a lower tray deck unplug it to eliminate them as the cause.
    Apr 07, 2017 | Xerox Phaser 7750 Laser Printer
    Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
    If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
    Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
    For further assistance, please contact Lexmark Technical Support
    Feb 09, 2012 | Lexmark T644 Laser Printer
    Problem with the Konica Minolta bizhub C450P Laser Printer Bizhub C450 error (C-0212) , HOW TO FIX IT?? PLEASE GIVE ME THE FIX STEP!! TKS!!!!!
    This code is for LCT (Large Capacity Tray) lock release failure. This means there is a problem with the LCT, usually the large paper drawer at the bottom. This code is usually reset by opening then closing the front door. Sometimes turning off then on the main power switch on the right side will clear it. Try releasing the LCT and get it open. Then check the paper in the tray. Most of the time when there are problems with these LCT's it is because too much paper has been loaded or it has been loaded improperly. If you get it open, remove all paper. Then load smaller amounts of paper at a time to insure that it is loaded perfectly. Only load the tray half full at first and then close the drawer and allow it to lift. Then make a copy from that drawer to be sure it feeds paper. Then release the drawer again and finish loading if you want. If you continue to have the code then you can leave the drawer open an inch or so to de-activate it so you can still use the printer from the other drawers until you can get a technician out ot service it.
    Good Luck and Thank You for using Fixya.
    Wheatland Services
    Feb 16, 2011 | Konica Minolta bizhub C450P Laser Printer
    I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
    Is there a paper selection wheel or bar in the tray?
    Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
    Dec 03, 2009 | Canon CLC 1150 Color Copier
    Trouble printing envelopes on kodak esp3 printer
    Have you tried this procedure?
    Loading Envelopes
    You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
    Important Do not use envelopes with cutouts or cellophane windows.
    1 Remove any other paper from the paper tray.
    2 Insert one or more envelopes into the right side of the paper tray with the print side down and
    the envelope flaps on the right, pointing left.
    3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
    4 Leave the paper tray open while the envelopes are loaded.
    If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
    Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    EP3050 error code C0040
    A C0040 error code indicates a problem with the suction deck fan. It has nothing to do with the paper lift motors.
    The fan is accessed by removing the rear cover of the copier. It is right in the center. These are readily available (p/n 9313-1310-61) although they are not cheap (around $200 retail).
    Nov 15, 2008 | Minolta Office Equipment & Supplies
    How to change the size of the paper on this printers
    Where is your problem?
    Changing the paper size and size adaptations are possible from the printer driver settings - just look into the tabs.
    Paper size of sheets is detected, when you load it.
    Roll paper is loaded in the drawer - and I think width is detected while the loading process.
    Please give more details on your problem
    Regards AToe
    Jun 03, 2008 | Canon imagePROGRAF W7200 InkJet Printer
    Canon Laser Class 3175 facsimile, incoming faxes are being saved in memory, will not print. Cannot clear error message "check paper size".
    The problem is that you have a fax saved in memory that is the wrong size for the paper you have in the drawer. Probably it is a legal size, whereas you have letter size in the drawer.Just place some legal size paper in the by-pass tray to print.
    May 11, 2008 | Office Equipment & Supplies
    Xerox Phaser 7750DN Laser Printer Logo
    114 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
