Question about Boating
I have a 03 90HP on my 22' pontoon. Only when I make left turn, it bogs down and alarm sounds. As soon as I straighten back up, it starts back up and runs good. Any idea's ?????
  • 677 Answers
This is just a thought.Water flow to the motor is being interupted by a fitting/object,that is in the flow of water going to the motor.It may be allowing air to enter the water pickups for the motor cooling.This could allow the pump to "cavitate" and set off the alarm.Get someone to look at the waterflow and motor as you do the turns and you may see something.Hope this helps
Posted on Sep 11, 2010
  • info88466 Sep 11, 2010
    Many thanks.......I'll check that the best I can.
Why does my mini tiller start then bog down and die as soon as i give it any throttle
Sounds like your carburetor is dirty and not letting enough gas get it to run. Also is there a screw on the carb to set the gas flow ? If there is turn it to the left to let more gas flow.
May 18, 2015 | Garden
The security alarm on my scooter sounds as soon as I turn the key. How do I reset it?
Hi davohoh.
Sorry for not replying sooner.
Not sure how much help I can be other than relating my own experience of this.
I've "stored" my own Piaggio MP3 250 (1997 model) a few times for "extended periods" and never really had a problem ....
(except once when it didn't want to unlock the tilt mechanism and just beeped at me when I tried - after trying many many times it just did it and never failed again)
.... until the last time in July 2014 when I had your ALARM problem.
It had been parked on June 15th when I went on holiday and left for 25 days - I returned on July 10th.
When I turned the key and the ignition lights all came on so did the alarm, sounding loud and constantly.
Turned it off and back on - still the alarm.
Repeated several times - still the alarm.
Seem to remember trying to unlock the tilt mechanism - can't remember if it did or not but the alarm kept sounding.
Tried starting it and I think it took a while turning over (definitely not an immediate fire-up - but this was probably down to it standing for almost 4 weeks) before bursting into life but it did start.
I thought this was quite surprising given the alarm was still going off and IF it thought it was being stolen, or was an immobiliser issue, that this would be possible.
I then definitely unlocked the tilt mechanism and rode it a very short distance (20 feet) - the alarm was still sounding.
Stopped, turned off the ignition and back on again.
Think the alarm went off again and I started it again.
Not absolutely sure but either the alarm just stopped sounding as the bike was ticking over, or it did after I turned it off/on and started it another once or twice.
Once it was "silent" it never went off again.
Stopped, started, drove, parked, left overnight, left 3 or 4 days, never had the same problem again in the 8 weeks since.
Strangely enough another fault got "fixed" whilst it was parked for these 25 days.
The remote control key unlocking of the seat catch had stopped working and hadn't worked for several weeks at least (possibly months) despite attempts to fix it (reprogramming?) as per a few suggestions I'd found on the Internet.
Sadly despite working for about 7 weeks since July 10th this failed a few days ago and I can no longer open the seat using the key.
The little green LED flashes on the key but there is just no click from the actuating solenoid. I need to look into this further - even change the battery in the key - just a thought !
Hope this helps
Aug 03, 2014 | 2011 Gilera Fuoco 500ie
The alarm won't go off
Try this:
SAVE radio code and remove the negative battery cable,turn on the headlight switch for 30 seconds,turn back off,start truck.
That MAY re set the alarm relay.
Mar 07, 2013 | 2007 Toyota Tundra
70 hp johnson outboard,was running fine,then started to blow black smoke from egsaust,lost of it ,then bogged way down
Well, the black smoke is most likely from too much fuel, perhaps a stuck open float valve in a carb. Fix right away, or risk engine damage. Carb surgery is next on your list.
Apr 07, 2011 | RTO Oar Sockets
We understand that your problem is: My 95 jeep
Have it towed to a car alarm specialist that is familar with Chrysler products. With a little luck they can fix it.. To reset alarm
(if it will work}, try locking drivers door and unlock it with the remote from outside.
The 5 second thing does not sound good.. Usually this locks your ECM out so it will never start. Thinks someone is trying to steal it.
Jul 29, 2010 | Cars & Trucks
Engine bogs down when ac kicks on
Check the Idle Air Control Valve. Any Service Engine Soon lights coming on?
May 28, 2010 | 2004 Dodge Stratus
1986 FOR BRONCO II v-6 ENGINE 4 WHEEL DRIVE AUTOMATIC 2.9 LITER
LOCATE EGR VALVE,, BELOW HOUSING, THIER ARE OPENINGS GENTLY, USING FINGER, INSERT IN OPENING, PUSHUP ON DIAGHRAM, WHEN YOU RELEASE FINGER IT SHOULD RESEAT AND SEAL,LISTEN TO ENGINE OPERATERTION FOR VARIATION TO IDLE, YOU HAVE JUST CHECKED TO MAKE SURE DIAGHRAM IS NOT BAD, NEXT CHECK VACMN TO VALVE,AND CONDITION OF HOSE.
Oct 05, 2008 | 1986 Ford Bronco
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
