Question about Maytag Neptune MDE5500AY Electric Dryer
How to wire a pass & seymour 15A-125V plug? - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 3,053 Answers
Hello, eliz I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
How to wire cfi red black red wite
1) Copy following link for wiring gfci
http://waterheatertimer.org/How-to-wire-GFCI.html
2) Add a comment March 2013 and say what voltage you are wiring, and what the wires connet to.
Mar 11, 2013 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
How to wire a pass & seymore 692 switch
Wiring diagram located at
https://www.legrand.us/passandseymour/light-switches/combination/led-lights/692ig.aspx
Jan 29, 2013 | Pass & Seymour #692LAGCC6 15A Almond SP...
I'm want to install a toggle switch/outlet but have 2 white wires and 1 black. It's a Pass & Seymour 691-WCC6 switch. Can I install this switch?
More information is needed.
Unknown what wiring device was there before, and which wires were connected to which screw terminals.
Wire color is not as important as knowing what wire is for.
If both white wires were connected together before, then they need to be put back same way.
Separate wires. Turn on power. Test each wire to bare ground. Tester lights up on Hot wire. The Hot wire is usually black.
In back of box are white wires twisted together and covered with wire nuts. These are the neutrals.
Test black hot wire to neutrals and tester will light up. If box does not have neutrals, then device cannot be installed to code.
Open following link for illustration of wiring:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Aug 01, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I have installed the Pass and Seymour combination GFCI and the test button disconnects the recepticles and the light remains on.
I believe the GFCI is only meant to protect the receptacle. Plig something into it and try the test button and it should work as expected.
Jul 07, 2011 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
I to want replace a regular duplex outlet with a TM818-WCC6 and want just the outlet switched. How do I wire it?
The Pass and Seymour plug-switch combo has 3 screws
There is a dark screw on one side .... the black Hot wire from breaker box connects here
There are silver and brass colored screws on other side of device
The white Neutral from breaker box connects to silver screw connects here >>> this will give power to your receptacle
The black wire going to Load (light, fan, motor that you want switch to control) connects to brass colored screw ... the switch controls power to Load
How to test for black Hot
Remove devices and separate wires
Turn on power
Test each wire to bare copper wire
Tester lights up on black Hot wire
How to test for white Neutral
Test black Hot to each white wire
Tester lights up on Neutral
Oct 16, 2010 | Pass & Seymour #TM818WCC6 15A White...
I'm in need of an inexpensive timer, preferably mounted in a wallswitchbox, which has two output circuits, one from a n/o and one n/c contact. Can you recommend a model? Thank you
Instruction sheet
Sales sheet
Deihl spa-and-pool timer shows a 15A DPST NC NO timer in sales sheet
Wiring diagrams show DPST.
However most 880's sold are 125V SPST.
Deihl makes 125 V, 24V and 240V models ... but I don't have product sheet that shows all models
I don't see any NO NC wall-timers while looking at: Woods, GE, Intermatic, Aube, Hagar, Leviton, Lutron, Paragon, Pass and Seymour, Swilight, Sylvania, Timex, Tork, UPM, Utilitec
Box timers by Intermatic offer NO NC:
T1900 series
T171
Ordinary 3-way switch is NC NO
Ordinary 4-way switch is NC NO can be wired to control 2 independent circuits
There are heavy load NO NC contactors (relays)
Item 2cg37
You can wire ordinary wall timer to control the contactor
Oct 08, 2010 | Hardware & Accessories
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
