Question about GE Washing Machines
MY WASHER WONT DRAIN WATER - GE Washing Machines
  • GE Master
  • 8,220 Answers
Easy fix. Remove the front panel. Get the shoestring or whatever it is out of the electric pump.
Posted on Sep 09, 2010
  • Dan Webster
    Dan Webster Sep 09, 2010
    Give a model number for a more precise answer. LOL
Ok I have a Frigidaire combo FEX831fs1. It won't drain. I replaced the pump and the belt. still wont drain. In the drain cycle it makes no noise at all. Spins, fills, agitates, just wont drain.
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Apr 11, 2017 | Frigidaire Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Ecosmart washer won't drain it filled with water, washed and nowwon't drain the water.
you need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
Feb 22, 2013 | Fisher Paykel EcoSmart GWL15
Sud and then f35 code comes on where can I find a picture of where parts are located on washer
to get picture of where the parts are go to searspartsdirect.com and enter your exacy model#
Now then the suds means basically that the washer didn't fully drain and the F35 means that water wasn;t detected entering the washer at the start of a new load...if all the water disnt drain it wont fill so what the biggest problem when that happpens and it wont drain is a blockage in the drain pump filter..here is what you do to check the filter screen for blockage is;oldtech2332_34.jpgoldtech2332_35.jpgunscew a little,use towels/tupperware tubs to drain ALL water..once all water out unscwer completly and check for blockage
Aug 20, 2011 | Kenmore Elite HE5t Washer
It wont work it flashes fl
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
G.e. washer wont **** out rhe water
I did all the tips to check the pump. Took washer a part and no luck. I was ready to haul it to the dump. As a last resort I put drain cleaner (dollar tree brand) in the tub and ran the washer on hot. After the cycle I lowered the hose inot a bucket and turned the washer on Drain. I heard a pop and the pump was free. Works like a champ now.
Mar 13, 2010 | GE WBSR3140DW Top Load Washer
My washer wont hold water
Hi
Make sure your drain hose is not sitting on the floor.
You need to make sure the drain hose goes up to the hight of the tank and then back down to the drain.
If the hose is sitting low, then gravity will just drain the water out.
Let me know if this is not the case and I will dry and diagnose if there is a nother problem.
Ash
Nov 06, 2009 | GE WBSR3140DW Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Apr 17, 2009 | Washing Machines
My washer wont drain
It sounds like you need a 2 way valve , its a valve thats suppose to recycle the water during the wash and then open so that the water can drain. it's at the bottom of the washer right by the drain hose.
Jan 09, 2009 | Kenmore Washing Machines
Washing Machines Logo
99 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
