Question about Prestige Aps95bt2 Elvat5c Replacement Transmitter
My existing PRESTIGE APS95BT2 ELVAT5C remote is broken. I can buy one on-line for $25 but how do i reprogram it when it arrives?
How do I disable this alarm system?
If you can find the control unit under the dash you can just pull the fuses.
Feb 02, 2014 | Prestige Aps95bt2 Elvat5c Replacement...
I have 2 remotes for my 2007 Honda CRV, 2 that unlocks the doors and 2 with a button you push to start the vehicle. One of the starter units won't work. I took it apart to see what kind of battery it...
Typically a car remote does not have to be reprogrammed to replace the battery. Check the car's owners manual to verify the battery is a CR1229. I don't know of any 1229 number but I do know a CR1220. Verify the number and you can buy them at just about any store...from Walmart on.
Semper Fi,
Z
Aug 08, 2017 | Prestige Remote Start
Valet/Bypass Switch Location 1995 Honda Accord
Wow no idea at all ,is this the original factory alarm or a add on one
Jul 17, 2013 | Prestige Aps95bt2 Elvat5c Replacement...
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
Bought a 2002 jetta that has a prestige remote start on it. it worked fine a few months. Today nothing works..it won't start, or even trigger the start sequence, and the door lock/unlock won't...
There are two possiblities that could prove to be the fault; hood pin switch and remote start shutdown switch. If the vehicle is equipped with a hood shut down switch, you will need to make an adjustment to it for the remote starter to function. Search around the drivers side edges of the engine compartment for a push pin.If the pin is a stand alone it will be mounted near the headlight inserted into an existing hole. It may also be attached to a bracket. The remote start shutdown switch is a toggle switch located under the drivers side of the dash,usually to the left of the brake pedal, depending on the installation.
If nothing above solves the problem, you may need to reprogram the remote to the unit.
May 23, 2011 | Prestige Remote Start
How do you progam a new one
Did you (or anyone else) find out how to program this. I need to program one as well. Elenib@sbcglobal.net
Oct 15, 2010 | Prestige Aps95bt2 Elvat5c Replacement...
Prestige Aps95bt2 Elvat5c Replacement Transmitter Logo
328 people viewed this question
Top Prestige Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Prestige Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
