Question about Dryers
I have a Casablanca Zephyr ceiling fan, and it is stuck on low. The chain sequence order is low, off, low, and off. What could the problem be? It has been doing this since I moved in last week.
  • 1 more comment
  • AsshoIe Sep 13, 2010
    There is no remote reciever.
  • AsshoIe Sep 14, 2010
    There is no little red light.
    I found a variable speed.
  • 96 Answers
The pull chain switch. Or it could be your capacitor. which is that little black box thats inside the fixture.
Posted on Sep 12, 2010
  • 2 more comments
  • AsshoIe Sep 12, 2010
    I looked at it and there is only 1 capacitor, and it is only 1 speed swtich for chain. It does not have a light kit, but if it does, it would go fan on, light on, fan and light on, off. How do I change speed on casablanca zephyr?
  • Matt Sep 13, 2010
    It might have had a remote with it. If you dont have a remote you can always change the pull switch.
  • Matt Sep 13, 2010
    If you have the fan apart look at that little black box and see if has a little red led light or sensor on it. If not then it deffinetly didnt have a remote. How many wires are coming out of that little box?
  • Matt Sep 14, 2010
    How many wires are coming out of the black box?
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Where can I find a replacement for the Glass?
    Casablanca sells parts. Go on-line to locate the part number you need from a schematic and either order directly from them or through a certified dealer. No worries!
    Apr 10, 2015 | Casablanca Fan Hampshire C7M62M Ceiling...
    I have a Casablanca ceiling/fan light with one wall switch. The fan will only work on high speed and makes a shrill type of noise. The light has worked but not consistently. I was wondering if I have a...
    is the switch made to turn on and change the speed, the switch is acting up should chang the switch, but if you change the speed with the chains the wiring is loose up in the fan just need to take it down and tighten up the connections,good luck.
    Aug 08, 2011 | Casablanca Fan 3245T Ceiling
    I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
    yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
    Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
    Just bought the house- it has a casablanca del mar but no remote- the wall switch does not work- can i override the remote?
    usually remote control for ceiling fans does not have an override code like the ones available for control using a universal remote. because they are specifically designed to work with certain IR or Radio frequency signals.
    Usually a replacement remote is available but you may have to contact the manufacturer to check for availability.
    Here's Casablanca Support phone number:
    Call Toll Free: 1-888-227-2178
    Hope this helps!
    Aug 03, 2011 | Casablanca Fan 3845Z Ceiling Fan
    Ceiling fan stuck on low
    in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
    Jun 07, 2010 | Hampton Bay 24002 Ceiling Fan
    Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
    I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
    Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
    http://www.casablancafanco.com/Parts-Manuals/Part-Manual-Detail?ModelNumber=54019
    Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
    I have a Casablanca Intelli touch ceiling fan. The remote is a simple toggle switch, turn in on, listen to the beeps, off an on quickly to set it. How do I reverse direction on this fan?
    My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
    Apr 01, 2010 | Casablanca Fan 3245T Ceiling
    Wire diagram for pull chain on ceiling fan hunter original
    if you indeed have a 23852 hunter original...
    Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
    Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
    Our casablanca ceiling fan has power going to the fan and the remote works but the fan does not nor does the light
    If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
    Jun 25, 2008 | Casablanca Fan 3245T Ceiling
    Dryers Logo
    232 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
