Question about Kitchen Ranges
I am getting a c1 error flashing on and off alternating with the temperature. The problem began right after a short power outage
  • 101 Answers
Board damaged by surge when power came on
Posted on Sep 10, 2010
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
How do I fix the code se flashing on my refridgerator?
5E or SE error appears when you have a shorted touchpad and the solution for this is to to put your fingers on the upper right and left sides of the display and the display will restart.
The reason why you are getting this is because when the power is restored there are events where voltages increase for a few seconds (power surge). It is recommended that if you have a power outage you should unplug the power cable of your fridge to avoid damage.
Let me know if this helps.
Jun 14, 2015 | Samsung RFG297AARS (285 cu ft) Bottom...
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Oven Door Latch Won't Stop Cycling
Contact your power company and request they repair the appliance that was damage due to the surge, it is likely burned out the control panel
Jul 08, 2017 | Kitchen Ranges
Magnets will not ingage
I repaired the same symtom that happend to one of the sides of my CPT-180 toaster. The magnets wouldn't engage due to a bad C1 capacitor on the circuit board that controlled that side of the toaster--the capacitor was bulged out on the bottom and turned out to be bad. I've attached some photos showing C1 bulged out compared to C1 on the good board.
C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down due to the magnets not engaging or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
Pictures:
C1_location (next to screw)
Comparing_good_C1_with_bad_C1--note bulge on bottom of right C1
Right_orginal_C1_and_left_replacement_C1
Bad_C1 showing capacitance, voltage and max temperature ratings
5487aa4b-7e7d-4e6f-9542-cf9ff618008c.jpg2d853c87-48b6-4735-99f4-fdd5dbc60ffe.jpge1a82299-a243-46e1-b11b-4c20e0d9b304.jpg5543b7e5-8108-4b1d-bed3-90eee4600722.jpg
Mar 28, 2014 | Cuisinart CPT-180 Metal Classic 4-Slice...
My Cuisinart Toaster's left side lights up
I repaired a problem with one of the sides of my CPT-180 toaster that was fixed by replacing C1. This may be the same component that Stan was referring to, as the C1 capacitor on the circuit board I was having problems with was bulging. I've attached some photos showing C1 bulged out compared to C1 on the good board.
C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
Pictures:
May 14, 2013 | Cuisinart CPT-180 Metal Classic 4-Slice...
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
My Kenmore range model C970-628091 keeps beeping and flashing an F1 or F3 error code when I try to bake at 400 degrees and whenever I try to use timer for baking. When I press cancel the beeping and error...
Fridgetech is right. It's the temperature sensor. I had the same problem, but I was getting the F3 and F2 errors when attempting to preheat the oven.
A R Marshall said that he replaced the sensor but he still got the same F3 error. That happened to me too! It worked for a few weeks, then it began to malfunction again. It finally started showing preheated as soon as the oven was turned on, but never heated at all. One night at 3AM, the error code and beeper went off while we were sleeping! That happened on several occasions at various times of day, and it was necessary to kill the power to stop it. The power could then be restored and the error would stop.
Ours is a Hotpoint range (made by GE). It's my understanding that most ranges have the same or similar error codes.
The sensor was $85.00 at the parts store, but I got it on line for about $60.00 including shipping. The instructions said to strip the wires and then twist them together with wire nuts. But the new sensor had a plug that fit so I used it, and it worked for a short while.
As I looked through the problems and possible solutions, someone said look for burnt wires. So I opened it up and looked but there was nothing like that. Then I remembered the instructions that said to hard wire, so I examined the plug which seemed to have one short wire inside. I plugged it back in and tested with the same negative results. Now suspecting the plug I cut off both sides, stripped the wires and hard wired using two small wire nuts. It immediatly began working normally!
Something is wrong with the plug connector.
Try cutting out the plug and hard wiring before ordering a new part. But if you need a new part, eliminate the plug!
May God bless you and keep you safe!
Sep 01, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
