Question about Mi T M Garden
Just need a part number, I have a CA-2003-HDHB pressure washer and I need the part number for the valve kit. also if you could direct me to where I might find a parts breakdown online for my machine, in case I need more part numbers. Thank you. Joe G.
SOURCE: How to install Amana part number 12001937 Thermostat kit
I have a Sears Maytag with a cooling problem. Meat is frozen but bread is soft. I am told it is a Amana. It is a bottom freezer. Did this part fix your problem. Let me know, I am going to rip mine down in the am. Bandit98
Posted on Jan 26, 2008
  • 7 Answers
SOURCE: Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
Posted on Apr 11, 2008
KMusselmann
  • 247 Answers
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
Posted on May 23, 2009
  • 351 Answers
SOURCE: Can't locate stacking kit for HE2 Plus Washer and HE2 Dryer
more of the model number would help, but i can get them parts for you at www.whirlpoolpartssurplus.com feel free to give us a call
Posted on Jun 23, 2009
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
http://www.sparesgiant.com/cleaning-equipment/pressure-washers/karcher/k-series-parts/k2-range/k2-36m16724300/
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
Power washer not spraying hard
Hi Mike
You could have one are two problems with the pressure washer.
1...pump for pressure washer worn and needs washer/seal replacement.
2...Need to adjust the pressure discharge relief valve to the needed pressure.
Please take time to rate me
Bud
Mar 28, 2013 | FAIP Powerwasher Universal Pressure Washer...
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Pressure wash gun not working, we are in kuwait
Depending on the brand of the gun you may or may not be able to fix this. Regardless it will require a repair kit to repair the valve in the trigger assembly. If you can provide a brand and or numbers from the gun I can direct you further.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Karcher Garden
Hy; I have a karcher 580 I had to replace gun complete so I bough a simoniz xe01-001 at simoniz.osirus.ca/ for your info 69$ complete ***.I install NOW I get pulse up & down ONLY when trigger is press...
Most likely problem is that the tip is too small causing Unloader to bypass or restriction/debris in tip. Install clean tip of proper size or 1/2 size larger (example from 2.5 gpm to 3 gpm ) to prevent slow pulse. If tip is clean and /or larger tip does not help, Unloader may be failing if the unit has a good deal of hours or if machine is left running for long periods of time without spraying. Try lubing the internal parts by removing both hoses and installing a short piece of water hose to intake and slowly inject light oil into pump by pulling on the rope slowly to **** in the oil until it comes out the pressure side. This will displace all the water from inside the pump. Leave overnite. There is a kit sold on ebay to help facilitate the infusion of oil but no need to get fancy. Unloader repair kit is usually available if all else fails and is easy to install. Good holidays
Dec 12, 2010 | Karcher 2500 PSI Pressure Washer
Leaky spill valve on karcher pressure washer
You should replace the thermal by-pass valve with a new kit, part number is 45803590
May 17, 2010 | Karcher G2650HHR Gas Pressure Washer
Lose of pressure on Campbell washer
Usual cause is the pressure valve sticks closed and doesn't admit more water to be pumped. Usually needs new O RIngs and cleaning the bore... ABout a 15 minute job at most. Get an O Ring kit for it.
The valve is held shut when pressure on the output is high. When you open the trigger, the pressure drops and the valve opens letting more water come in from your garden hose.
The O RIngs dry out and bore gets dirty. Polish it with crocus cloth on a dowel rod. Lube the O Rings with lube intended for O RIngs.
May 08, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
May 06, 2010 | Karcher 1750 psi Electric Pressure Washer
No pressure in power washer.
usually you can get a seal kit for your pump. I would need the model number to direct you to the parts you need.
Sep 03, 2009 | Garden
Garden Logo
179 people viewed this question
Top Mi T M Garden Experts
andy just round the...
Level 1 Expert
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
