Question about IBM TotalStorage DS4700 (181470H) Hard Drive Array
IBM Total Storage DS400 I just did a ot sway
IBM Total Storage DS400 I just did a ot sway replacement of a failed controller.... IBM ServeRaid mgmt displays the same same failed controller status. Current config has two arrays, 4 x 136GB drives each. The working controller has been managing both arrays for some time now. Any Ideas. I just signed up to FixYa so I hope someone may have doen this one before. Thanks
  • 5 more comments
  • Dwayne Sep 13, 2010
    Thanks for the response Tim. Srry about the mistypes. I meant to say a "hot swap replacement" Im not certain the procedure to remove the defintions from the system that you referenced. I hope you can explain that further. More details on the storage center... IBM DS400 1700 2RD. Connecte vis fiber to my BladeCenter. The current configuration has one controller managing two storage arrays. Both arrays comprised of 4 x 146GB hard rives. It has been that way since I joined the company. The second controller has always had a failed status. I hope this helps. I not very familiar with the setup of such storage arrays. I included a pic and a screenshot from ServeRaid Manager. Let me know what you can, thanks much
    I reply to a response you posted to assist me with a situation with my storage center IBM DS400. Im new to FixYa so I just wanted to confirm that you got my reply. Thanks for the response.
  • Dwayne Sep 14, 2010
    Thanks again! I can tell Im working with a brain here. I didnt try a power down reset since the swap. There are two lit LEDs on the back of the new controller, the 'cache dirty' and the 'controller not ready' both are amber. I read up on what both of them meant but didnt find a fix. It was not a brand new controller. Didnt want to foot the high costs for new :) One half of the array is my live exchange server so a possible shut down wont happen til teh weekend. Any suggestions til then. I'll work on sending some high def pics til then lol
  • Dwayne Sep 21, 2010
    IBM Total Storage DS400 I did a hot swap replacement of a failed controller... The IBM ServeRaid Managment tool still displays the same failed status on the controller. I also did a restart of the controller with the ServeRaid tool. There are two lit LEDs on the back of the replacement controller, the 'cache dirty' and the 'controller not ready' both are amber. Current config has two arrays, both comprised of 4 x 136GB drives each. One of the arrays is store location of my exchange server. The other is spare. The working controller has been managing both arrays since I joined the company (3 years). Any Ideas on what else I can do to activate or initiallize the controller. I just signed up to FixYa so I hope the experts here can help Thanks much! If you need screen shots or anything further let me know.
    The Config status of the failed Controller B is below
    Controller B
    Vendor..........................Not available
    Model...........................DS400
    Serial number...................Not available
    FRU part number.................A
    Processor memory size...........128MB
    Processor cache size............112MB
    Controller slot.................B
    Primary radius server hostname..
    Primary radius server port number1812
    Secondary radius server hostname
    Secondary radius server port number1812
    RAID firmware...................4.1-0 (6943)
    RAID device driver..............1.1-5
    Boot image 1 firmware...........IBM TotalStorage DS Series
    Boot image 1 firmware...........5.87
    Boot image 1 build date.........04/02/2005
    Boot image 2 firmware...........IBM TotalStorage DS Series
    Boot image 2 firmware...........5.87
    Boot image 2 build date.........04/02/2005
    Current boot image..............Boot image 1
    Image to use at next boot.......Boot image 1
    Controller status...............Failed
    Battery status..................Okay
    Battery charge amount (%).......100
    Estimated charge remaining (minutes)6634
    Host name.......................ds400
    Domain name.....................
    DNS entry 1.....................10.0.0.21
    DNS entry 2.....................
    Default Gateway.................10.0.0.1
    Host interface type.............Management
    Link speed .....................Auto
    IP address......................10.0.0.41
    Subnet mask.....................255.255.0.0
    Broadcast address...............10.0.254.254
    MAC address.....................00:00:D1:DE:38:CC
    Full duplex.....................Enabled
    Host interface type.............Fibre
    Device driver...................01.01
    Firmware........................3.03.03
    World-wide node name............20000000d126704e
    World-wide port name............21000000d126704e
    Link state......................Up
    Link speed .....................2Gbps
    Topology........................Fabric
    Current fabric ID...............10000
    Current AL_PA...................0
    World-wide port name............21010000d126704e
    Thanks I'll try it this or tomorrow evening
    tbreeze, had a question. I usually power down the server that uses the storage array when I shutdown and restart the enclosure. Is that necessary.
  • Dwayne Oct 01, 2010
    Hi, thanks for the response. I did the full system reboot but unfortunately it still seem to not recognize and activate the replacement controller either. I have the ServerRaid Manager up and Im im not certain what all "safe" options are available through it. If you are familiar with it please offer any suggestion that you can. I was wondering how safe it woudl be to swap the controllers as see what happens. Im a little timid b/c one of the two arrays is my MS Exchange data store.
  • IBM Master
  • 12,061 Answers
OK, things that may cause this, The MotherBoard has developed a fault. To my mind, It is unlikely that TWO RAID controllers will go "Faulty" simultaneously? You need to test them BOTH to isolate the problem. and see if indeed it is the actual controllers?
What you need to do, is check those RAID controller IN ANOTHER system, and see if they are even functional? IF they are, then this more points to a faulty MB. Also check the Power Supply unit too, I have seen misbehaving PSU's cause RAID Controller problems.
Although they are "Hot Swap" that still doesn't mean that they haven't gone faulty from the motherboard, removal/ insertion?.
Also Check the RAM, if this faults, it may interfere with the controller.
Posted on Sep 22, 2010
  • 3,083 Answers
This sounds like the ServeRaid isn't recognizing the new controller, and the software needs to be reset and initialized. A complete system reboot will probably (and hopefully) reset and recognize the replaced controller.
I assume you have a manual, but in case you don't, here's one:
http://www-947.ibm.com/support/entry/portal/docdisplay?brand=5000008&lndocid=MIGR-64387
Good luck, and hope this helps.
Posted on Sep 21, 2010
    President:
  • 2,777 Answers
Hello there, I am a former IBMer that worked with storage arrays all the time, but I am confused on your issue here. I think you may have missed a few characters in your first couple sentences here:
IBM Total Storage DS400I just did a ot sway replacement of a failed controller.... IBM ServeRaid mgmt displays the same same failed controller status.
So have you replaced the failed controller? Sometimes you need to remove the definition from the system of the one controller and re-add it for it to recognize, but shouldn't need to.
Let me know some more info and I can definitely help you here.
Thanks Tim
Posted on Sep 10, 2010
  • 4 more comments
  • Tim Grayson
    Tim Grayson Sep 13, 2010
    Yup I got the reply, hmm, ok that makes a little more sense in someways, but is strange in others. If it is in fact the controller backplane that you swapped it should recognize that without much issue. Have you tried a full rest of the DS400 since swapping? Also, do the lights still indicate failed on the actual controller? Was it a brand new part swap-out from IBM?
    Let me know these things and we can keep going, thanks for the pictures, that's really slick, I think you're the first person I've ever seen post pictures that were helpful! :)
    Tim
  • Tim Grayson
    Tim Grayson Sep 14, 2010
    Hmm, cache dirty eh? That's peculiar indeed. Was that light lit up on the previous controller that you just replaced? Definitely take some more pics if you can, and if you can email me that screenshot that you took, along with any other screenshots you may think would be useful, over to me at microtechftp@yahoo.com ? It is too small to see exactly what's going on in that picture.
    Thanks!
    Tim
  • Dwayne Sep 15, 2010
    I beleive the same lights were lit of the last controller but Im not certain. I'll shoot a few other pics to your email in a minute
  • Tim Grayson
    Tim Grayson Sep 22, 2010
    Hey there, I never heard back from you, or if I did I never noticed the message, did you try resetting it?
ServeRAID-7k Controller SCSI Controller error code 2807
Hi dude,
i already answer the same problem as yours, on my case it's because swollen battery push the RAID memory and make it bent, so the contact point become loose, if you want more detail see on:
http://hubpages.com/hub/IBM-error-code-2807
Apr 05, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Serveraid m5014 is installed. when i ran serveraid manager, it cannot see the m5014 controller. can you help?
In order to detect the controller you have install Mega raid manager not the one you installed
Download it from the below link.
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5077712
Hope this would work.
Please don't forget to vote me if you are satisfied
Thanks
Jan 21, 2011 | IBM SERVERAID M5014 256MB SASSATA LP HBA...
IBM Serveraid 7K onboard not responding properly error code 2807
Have you updated the raid controller firmware? 7.12.13 is the latest, search ibm.com for migr-62540
Aug 06, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Troubleshoot ServeRaid problem on IBM x335 Box
The likelyhood that 2 drives fail at the same time is remote. I would first look to teh controller as the problem. Also, check the power supply. The only common things are the 5V and12V supply.
Dan
May 12, 2010 | IBM eServer xSeries 336
Problem with new array.
Do you see your new disk in the "Disk Management" window? To get there go to "run", type "compmgmt.msc", then click disk management. If you do see the disks there, then you need to format the disk to a "basic" configuration. If your new disk/volume does not show up there, I would suggest a hard reset on your server whenever possible. I see this issue at times with Windows and newly added storage array logical drives.
Aug 31, 2007 | IBM Total Storage DS400 (13n1777) Fibre...
IBM TotalStorage DS4700 (181470H) Hard Drive Array Logo
1,192 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
