Question about Lionel Pennsylvania Flyer Train Set
Sound in tender for Lionel 6-8309 not working properly. Sound muted. Whistle not working.
5 Suggested Answers
SOURCE: my lionel train won't run at all. What do I do?
Did you ever solve your problem? My son is having the same problem.
Posted on Dec 05, 2010
  • 2841 Answers
SOURCE: Lionel 618 tender. Whistle
The symptom you describe is in part due to the way Lionel designed their
whistles controls. The old style copper oxide rectifiers Lionel used (to
produce the low DC voltage to activate the whistle control relay in the
tenders) will overheat if they carry the full current drawn by the train for
an extended period. Lionel whistle switches are arranged to deliver the
full DC as the switch is partly depressed (to pick up the control relay in
the tender), and then at full travel to add a resistor shunt around the
rectifier to reduce the current flowing through it. This slightly lowers
the DC voltage, but should still be enough to hold the relay closed.
The fact that the whistle blows means your copper oxide rectifier
is probably ok. One possible problem is a dirty or bent contact on the
whistle control so that it is now properly adding the shunt resistance at
full travel, or may be interrupting the circuit through the rectifier. The
other likely problem is the whistle control relays in the tenders. These
are very sensitive devices that need to have clean contacts and proper
adjustment to work. Take the top off the tender and connect it directly to the transformer (by setting the tender on a separately
powered section of track, or by using test leads, but be sure the tender is
in the normal level position). Watch the operation of the "flapper" at the
bottom of the relay, and the alignment of the contact. I clean the contacts
by using a pencil eraser or if they are really bad by gentle using one of my wife's fingernail emery boards. There are two 1/16" square bent tabs at the pivot end of the "flapper" - they need to be
carefully adjusted so the moving end does not bind in its guide. You'll find more help on the Lionel Service manual pages at the Olsen's Toy
Train Parts site. Start with:
http://pictures.olsenstoy.com/searchcd31.htm?itm=708
but there are several other helpful sheets in the "Whistles" index as well.
Good luck
Posted on Aug 13, 2011
  • 13 Answers
bad connections, wires to/from the transformer, or maybe a real dirty track.
try spraying a very small amount of CRC [brand ) 226 it is better than any contact cleaner on the market. do not get it on the rubber traction wheels on the engine. If you do, wash off with alcohol using a cotton swab on the rubber band on the traction wheel.
Posted on Nov 20, 2011
residentoccu
  • 161 Answers
SOURCE: Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Posted on Mar 02, 2013
Coupler will not stay closed on tender this was new out of the box
Contact Lionel Customer Service for a repair/replacement or take the tender to a Lionel Service station.
Jan 27, 2016 | Crafts & Hobbies
Lionel 2466WX Tender -- HOW do I get it to WORK? (Assuming that it does work)?
Good work, Dan! Fixing trains can be as much fun as running them.
Apr 22, 2014 | Crafts & Hobbies
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
Lionel train problems
Make sure the A or D terminal is connected to the center rail. U terminal to the outer rail. First do this without the sound activation button. Horn should sound this way. Once this works correctly, add the sound button in on the center rail lead (A or D) If the sound activation button activates the horn, reverse the connections to the sound activation button.
This should solve your difficulties
Dec 04, 2013 | Crafts & Hobbies
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
Dec 03, 2012 | Lionel 11000 Holiday Tradition Express...
Our Lionel Holiday Tradition Express Set 7-11102 will not move even though all of the other functions work properly
Did you check the reverse switch? Be sure that it is turned ON. If your locomotive still will not run, check that there are no fibers wrapped around the wheel axles or any exposed gears. If none of these fix the problem you will need to take your locomotive and tender to a Lionel Service Station.
Dec 21, 2010 | Toys
Lionel Pennsylvania Flyer Train Set Logo
316 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
