Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Viking Trash Compactor VUC181SS will not open - seems to be locked - but moving to unlock position does not help
3 Suggested Answers
SOURCE: Have a Viking trash compactor
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Posted on Oct 21, 2008
  • 338 Answers
SOURCE: viking trash compactor DUC180
any appliance part place you need your model number.
if you have your owners manuel it may say who to call
Posted on Nov 26, 2008
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
Tip
Trash Compactor Problems Why it Does Not Work
Trash compactors can be a very nice feature and addition to your kitchen. However they can also be very hard to work on if they go bad. There are 20 some brands of trash compactors available, but the KitchenAid trash compactor is one of the most common.
If your trash compactor does not work at all here are some things that you will need to check.
First off make sure that you are getting power to the unit. Many are plug into by code a GFCI wall socket. These outlets do a great job of protecting against shock, but do a terrible job of staying on, especially when used on a motor that pulls a high amount of current when starting. It is not uncommon for them to go bad and trip for no reason at all after a few years. If the outlet is tripped, try to reset it by pushing in hard on the reset button in the center of the outlet.
If you have power at the outlet, then you will need to check through the circuit in the compactor. This can include a door switch, micro switches that sense the position of the ram, and possibly a key switch. Make sure that there is nothing stuck behind the drawer that would keep it from going fully shut. Check the position of the ram to see if it has returned all the way up.
If your ram is stuck down or if it will not go down, check for broken drive gears, belt, of chain. Make sure also that the switches that sense the ram position have not move and come out of place.
Your trash compactor will also need to be clean periodically. Food spilling on the tracks or glides can cause the drawer to slide hard or even become stuck. Clean all the slides or glides, wheels tracks and such with warm damp cloth and the re oil everything with a household lubricant. With time and use the wheels and bearings may also need to be replaced to keep your trash compactor operating well.
on Feb 28, 2010 | Kitchen Appliances - Others
I want to install a vinotemp Model: VT-TC32SB. Currently, there is a trash compactor in the space. If I pull the trash compactor out, can I just slide the fridge in place? The countertop and cabinets are...
Hi, It depends a little bit on how your trash compactor and cabinetry are currently set up. Some people have a tough time getting the trash compactor out/cooler in because of the lip that comes down off their counter. However, if you can pull one out, you "should" be able to just slide the other one in. Likewise, you'll need to be sure there is an electrical outlet available in the space. Usually, this isn't a problem as your new Vinotemp will plug right in where the trash compactor was plugged in. But in very old houses sometimes the trash compactor was wired right into the electrical. As long as your counter/cabinets were designed with enough room to move units in/out, this change should go smoothly for you. Best of luck!
Aug 30, 2011 | Refrigerators
I have a GE trash compactor I have to hold up the foot pedal for it to work. When I let it go the compactor stops. thank you
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. I have checked the...
Sounds like the motor that turns the reduction gears which ultimately pushes the ram could be seized up. If an object was jammed inside which was to much for the motor to handle it could cause it to draw too much current seize up the motor.
Jan 24, 2010 | Microwave Ovens
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
Good luck,
Jon B.
jbroccoli@aol.com
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Stuck Trash Compactor
I can't get to the rear of the compactor. How do I get the front off to get to the rest of it?
Mar 14, 2008 | Dishwashers
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Nov 20, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
102 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
