Question about GE (PSS26MSRSS) Side by Side Refrigerator
I'm getting water stains on the front of the fridge from the water/ice dispenser.How do I remove them? Thanks in advance
  • 101 Answers
Try white vinagar
Posted on Sep 10, 2010
My whirlpool ed20db ice maker isn't making ice. Inlet tube is frozen solid
Thanks for the model number. The water control valve=> W10245167 Water Inlet Valve will need replaced when this happens. Problem allows water to leak slowly into the ice maker and fill tube can become solid very quickly, or very messy ice formations coming down from ice maker, Thanks John Tripp Appliance 911
Jan 28, 2014 | Whirlpool Refrigerators
Ice tray not filling
The unit will not allow water to enter the frig til the temp is cold enough to make ice.
Nov 06, 2012 | Bosch Refrigerators
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
No ice and no water dispenser
Would have to talk you thru with chat .
Jul 17, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool Gold Side by Side Refrigerator
hi. thanks for the question .in the front of fridge where the ice # water is located . inside the door ,there are two switches and they don't always make contact. work with it, till it gives out completely. thanks the appliance doc. please rate me thanks
Sep 22, 2008 | Whirlpool GD2SHGX Refrigerator
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
Frigidair frs22zrf side by side w/ front ice and water
From what you are describing, it sounds like you need a valve. Another common thing I run into is the cooling tank inside the fridge freezing. This will usually affect water through the door only. Remove the crispers and you should see a large coil of plastic water line attached to the back wall of fridge. You can check to see if it is frozen by blowing through it from the end of the line you removed from valve. BEWARE, if you blow through it, water will come out dispenser if line is not frozen. Have a towel at front of fridge.
Oct 03, 2007 | Frigidaire FSC23F7D Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
49 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
