I bought a used Toshiba Satellite P35 motherboard. I have it wirking fine except the fans start blowing on high when I plug in the power and never stop or even slow down. I changed out the fans but it made no difference. When I mash the start button the light comes on as it should and the laptop starts up going to windows XP. The fans never slow down or stop even when I turn the laptop off with the start button. They only stop when I pull the power plug. Any suggestions?? Jim Jackson
  • 2 more comments
  • amfriction Sep 09, 2010
    No, I cannot tell you what it came out of and it did not have a CPU. The CPU I put into it came out of a S609 and has a speed of 3.20 GHz. They all look the same to me except some has different CPU's in them. It is not out of a S6292 because they have a additional cooling attachment and this board does not have it.
  • amfriction Sep 11, 2010
    Thanks a lot for the info.
    Jim Jackson
    Jim Jackson
    I tried but it said my bios were already up to date. Fans still blow hard all of the time. Thanks,
    Jim J.
  • 905 Answers
Hello Jim,
Check the BIOS setup / Toshiba Configuration for fan control. There are different options for when using the adapter.
But, they should turn off when the computer shuts down. You are likely looking at a fan controller failure, which is part of the power control. This board is replaceable, if memory serves.
Try contacting sparepartswarehouse.com and drilling down to your particular model.
Posted on Sep 10, 2010
  • Sheldon Dedek Sep 11, 2010
    I did some more research on your particular board, it looks as if the power control and the motherboard are 1 piece, the power control is not a replaceable unit.
  • 734 Answers
Hi Jim,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Go to this page and select the exact model of P35 (there are many) and then click the red GO button. You will arrive at your laptop's driver resources. Be sure to select the right Operating System and then choose the most recent BIOS download for your laptop (by date), download it and install it per instructions.
That should calm those fans right down. It would be a very good idea to read the descriptions of the other drivers there and load a number of them to make your machine operate correctly.
Regards
Posted on Sep 11, 2010
    Master:
  • 497 Answers
Can you please tell me the Exact Model Number for the motherboard? i.e. P35-??????
Posted on Sep 09, 2010
Toshiba Satellite Pro P35-S605 beeps upon power up then crashes and reboots.
Can you get into Safe Mode? I suspect your configuration needs tweeking.
Also I would immediately go into the Bios and make the boot order be CD, HD.. etc. Also make note of any hidden partitions such as H, or K. Those sometimes house a mirror of the factory version of XP... like when it was new.
Good luck
Nov 20, 2012 | Toshiba Satellite P35-S605 Notebook
Toshiba P35 S6292 - LCD screen is all in coloured verticle and horizontal lines dancing around. Can work with notebook OK when on set on low screen resolution with large print. External monitor is fine. No...
if Display is OK in Low resolution then its the Graphic Chip Problem. take it to the service center. there they can replace graphic chip or the motherboard. best of luck
Jan 19, 2011 | Toshiba Satellite P35-S6292 Notebook
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba P35-S611 wont power on! When i plug it in no led lights come on, i get nothing out of it. the led on the battery charger lights up but nothing on the computer, someone said maybe the motherboard? ...
yeah if you are planing to do it yourself..it is worth ..I just bought last week a broke one and I payed something under 100$ ..and I changed the motherboard in one that was doing the same..so ...if you think you will use it ..its worth looking on ebay ..or parts to buy what is missing
Anyway check the power line on the motherboard ..it may be just something unplugged..or a little part..but if it does not get any power..its just that ..
The fact that is charging the battery it means that the power is ok from the charger and the entry on the board...so check the ram memory ..and the power cable of the board...cause if the charging is ok ..and the fan is working ..it may be something like a cable or the switch itself..( in this case the switch board is changeable in a few minutes and has just a plug and 2 screws..
May 08, 2010 | Toshiba Satellite P35-S611 Notebook
On toshiba satellite P35 series laptop, the DC
If you are good using a soldering iron on a PC board, you can replace the power adapter jack on the motherboard. If not, you should take it to a repair shop and have it taken care of. The cost to have it repaired at a shop should not exceed $50 including the part.
Nov 12, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite Pro L10 - Fan does not work!
Take out fan from CPU. test it using external power Batt 5v. if its works, its could be your motherboard going to spoilt soon..
Oct 27, 2009 | Toshiba Satellite L10 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
P35 Shuts down
Go into Toshiba Power Saver in Control Panel and set Processing Speed and Cooling Method to midrange. You will not have the problem anymore.
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba P30/P35 Power keeps shutting down
An overheating occured on the unit that why it's shut off when the high limit of temp. reaches.
Try to use a lap cooler, it may reduce an overheating to the unit,
Mar 06, 2008 | Toshiba Satellite P30 P35 Series Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
