Question about Kenmore Washing Machines
Kemore front load model # 970-C45092-30 shows an E20 just before the final drain and spin of the normal load...cycle ceases...what is a E20 code?
wagdom
  • 64 Answers
SOURCE: indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Posted on Oct 31, 2007
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Posted on Aug 22, 2008
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
  • 4 Answers
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Posted on Mar 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code E20
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Will not drain and spin keep beeping with error E20
  1. Remove the 2 screws on the bottom and the front access panel comes off.
  2. Pump is on the right, remove hoses from it, remove pump from machine and remove whatever is in the pump.
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin LEDs should light. Any error codes should be displayed when holding those keys.
Feb 27, 2011 | Frigidaire ATF6000ES Front Load Washer
I have Kenmore front load washer(don't have the model # yet)...during the normal wash cycle..at the end of it it does not spin, the diplay show E20. What seems like the problem??
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Aug 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load Washer will not do a final spin
my front load washer wont final spin and show me e20 code
Aug 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
E20 ERROR CODE
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Jun 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Washer won't drain water
My will start to cycle and then it will cease to spin. No grinding, no off balance noise-no spinning=no draining of water from tub/basin. Unplugged it for a full 4 minutes. Plugged it back in. Checked to see if washer was level-it wasn't. Made adjustments to ensure washer was level-EUREKA! washer finished cycle no problem. BOO-HISS! Two loads later, same issue as the first time-washer won't spin. Checked to see if washer was still level-it is, new issue-error coed E20 and all lights blinking. ANY suggestions?
Jun 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
350 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
