Question about Homelite Mighty Lite Lawn Trimmer
I have a Homelite Easyreach Model # UT20044A that will start, but then dies. Cleaned the filter, spark plug but still dies
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Check that the carburettor and fuel lines are clean. If the unit has not been used for a while the gas (petrol) will evaporate leaving the oil behind to choke up the fuel system. Dirty fuel will do the same. When adding fuel use a funnel with gauze filter in it and always empty the fuel tank and then run the motor until it dies when you've finished work.
Posted on Sep 10, 2010
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I also have a Homelite Easy reach. I emptied all the gas. Replaced the spark plug, replaced the fuel filter and fuel supply and return lines, but still would not start. At full choke the engine would start, but die out unless I flipped the butterfly to run and gave it full throttle. The carb adjustment screws are "tamper-proof", but I took a utility knife and cutaway the plastic exposing the screw adjustments. Turned both screws clock-wise all the way in, and then 2 turns out, and it started right up. I had to do some adjustments after this, but runs great now.
Posted on Apr 17, 2011
    Problem Solver:
  • 14 Answers
If there was fuel/oil mix left in the tank for a long period the ceramic filter in the tank may be gummed with oil. You can carefully remove the filter after you empty the fuel, ensure while pulling filter hold line for it may fall back into the tank. Then you may have a time fishing the line out. Clean ceramic filter with carburetor cleaner, Re-install filter. Don't forget to replenish with fresh fuel mixture according to specifications for your trimmer.
Posted on Sep 11, 2010
Check spark?
Benjamin, remove spark plug, attach plug wire onto plug, hold end of plug against cylinder head or a metal fastener that you know is going into engine for good ground. Make sure engine switch is in the on position, now pull engine over, observing the gap in plug for spark. If no spark get a new plug and try.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to check for Spark Plug Fire in any engine
How to Check the Spark Plug of Trimmer or Edger
Homelite String Trimmer Won Start No Spark
Jun 17, 2016 | Garden
Homelite ut80522d pressure washer motor reves up and down then dies
It's surging... your carburetor needs to be serviced. It's not giving the proper air fuel ratio to the engine...
BriMaxSmallEngineRepair
Gibbstown,NJ
Jul 26, 2013 | Homelite Gas Pressure Washer: 2700 psi 2.3...
Homelite 240 20" oil blowing out exhaust
Your machine need s a complete overhaul.Gas & oil out of exhaust is problably due to wear piston rig and camshaft.
Oct 25, 2011 | Garden
What's the gas oil ratio for model UT20044A Weed trimmer?
Homelite says to use there Premiums Exact Oil at 50:1 ratio. Then they say if you don't use the Premium Exact to use high grade 2 cycle at the ratio of 2.6 oz. per gallon of gas. That also works out to very nearly 50:1. Do not use regular motor oil.
Thanks for using FixYa.
Gaker
May 16, 2011 | Homelite Garden
Hello homelite 25cc string trimmer model # ut20042 it will start up just fine. after it gets warmed up and I open up the throttle on it, after a min or two it will die, sounds like it is flooding, the...
Hi, try bringing the high speed mixture screw out a quarter turn. There are two screws side by side on the carby, it is the one closest to the air filter. If that does not work there is a spark arrestor screen in the muffler that may be blocked. This can be cleaned with a wire brush and refitted. Regards Phil
Apr 26, 2011 | Homelite Garden
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Jul 13, 2010 | Homelite Garden
My Homelite UT-20002A trimmer have a hard starting problem. I remove the muffler and cleaned the carbon in the exhaust port. I also replaced the spark plug, but still the trimmer is dificult to start.
If you can, check to make sure there is a spark. Check the plug and notice if there is a presence of gas/oil mix on the plug or in the cylinder. Also, make sure the air filter is clean Try to make sure all bolts and screws are tight as lots of vibrations can loosen some of them.. An air leak on the engine could be causing your problems. A carburetor that is in need of a rebuild will do the same.. Finally an engine that is badly worn and has weak compression will not start, period.
Nov 17, 2009 | Homelite Garden
Mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Nov 20, 2008 | Homelite Consumer Products MightyLite...
Homelite Mighty Lite Lawn Trimmer  Logo
892 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
