The F - 1 error code shows a failure of the PFC & IPM circuit boards inside the outdoor unit.
We stock a complete line of Amcor parts. [email protected]
201-266-8234 option 2
All i can tell you is the system is a sealed system and you need to install line taps on the suction line. It is the larger one on the compressor. Like i said before you can not buy R-22 with out an epa card. That is how you would charge the system, low side line tap.
had the samething. 2 blown capacitors on that middle board. got new capacitors and system was back online. check out digikey electronics and order your new capacitors. hope nothing else is wrong with the board.
Because the model numbers are based on the country in which you bought the unit, you will have to do the research yourself on the error code for your unit. Once you find out what the error code is you can determine if low refrigerant caused the problem. Here is the contact info website to download your manual. http://www.amcoraire.com/index.html
I have since found out that you have to actually go into your contacts under yahoo mail and delete them from that list, then it deletes them from your messenger. Found this solution on another website. Hope this helps anyone else who is having that problem.
Take the SD card out and put a different one in with mp3 music files on it and you can use it as a mp3 player. DO NOT use the original SD card as you will delete the data that is necessary to use it as a GPS. I don't understand why anyone would want to use this as a mp3 player. Sound quality is terrible.
I am pretty sure that all of the maps and drivers are on this download named IGO Flashdisk software. This should be what came on the disk to begin with. http://www.amcornavigationusa.com/eng_support.html
