Question about Sunbeam 701 Humidifier
I have a Sunbeam Seaview H how do I clean itumidifier
When i plug in my sunbeam humidifier I get an er on the screen what should i do
Impossible to know without communicating with Sunbeam. "ER, ERR" and the like are normal failure mode displays whenever the unit can not operate as normal. As there are electronic components involved, a failure of any one will fault the unit.
And it could also be something as trivial as a buildup of scale on the water sensors. (Have you tried a thorough cleaning of the unit?) I would first try soaking the water chamber in white vinegar for several hours.
It that does not fix it, it's probably done for.
Jan 03, 2016 | Sunbeam SCM631-UM Cool Mist Tower...
Looking for a replacement tank for a Sunbeam SCM630 tower Humidifier
This is totally bad product from sunbeam maybe they need to find better quality stuff I have only had mine for one month and went to fill the tank and it has a big crack in it. It was never there before so sunbeam I will not buy your products again they are cheaply made
Jan 22, 2012 | Sunbeam Humidifiers
My sunbeam humidifier model SUL 495 does not seem to be working right?
Is there a filter or strainer where the water is pulled up? if so clean it, also you can run some kind of decalcifying product through it like CLR, which is non toxic.
Dec 14, 2011 | Sunbeam Humidifiers
I purchased a used Sunbeam Humidifier SWM5602 and need the manual. I have tried to search it and get a free copy so I know how to operate and clean it. Can you email me a downloadable copy of the manual?...
Lana, apparently that Model Number may have been discontinued. However, your Owners Manual may be available by calling Sunbeam Appliance @ 888 -264-9669.
Hope this helps you get the manual.
Rich
Mar 29, 2011 | Sunbeam 701 Humidifier
My unit wont start
You throw it away. If you must, you can disassemble the unit and clean the metal rods that go into the resevoir, sand paper works well for this, they corrode and won't conduct, cleaned off they almost always work, at least for a little while, but two or three cleanings is usually all they will handle before the rods are simply gone, eaten away by corrosion...
Feb 20, 2010 | Sunbeam 1387 Humidifier
I'd like to clean my sunbeam warm mist humidifier
if you mean by stone build up, you need a de scaler such as clr from any hardware store. let it soak on the crusty parts overnight the rinse well with water. toothbrush helps too.
Nov 25, 2009 | Sunbeam Health at Home Warm Mist...
How do you clean the 705 ultrasonic humidifier
You can soak everything but the motor in bleach or vinegar water. Rinse well with HOT water.
The filter is disposable, cleaning doesn't help with them.
Nov 18, 2009 | Sunbeam Ultrasonic Humidifier
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Mar 17, 2009 | Sunbeam 701 Humidifier
Cleaning problem for- Sunbeam 646 2 Gallon Cool Mist Humidifier
NO . Brush off as much as you can get off. Buy a xcan of compressed air or find a place that has compressed air and blow it out. I do not believe it to be safe placing a motor into a bleach/water solution.
Dec 26, 2008 | Sunbeam 646 Humidifier
Sunbeam 701 Humidifier Logo
87 people viewed this question
Top Sunbeam Humidifiers Experts
Paul Sikkema
Paul Sikkema
 steve
steve
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
