Question about Samsung NV4 Digital Camera
MY SAMSUNG NV4 CAMERA WON'T SWITCH ON AND THE CHARGER IS FLASHING ORANGE DOES THIS MEAN IT ID NOT CHARGING?
SOURCE: I have a Samsung P800
I have the same problem
Posted on Sep 22, 2008
zohail
  • 1223 Answers
SOURCE: When charging my camera the charger light flashes
battery issue try changing the batt they are not taking the charge pls replace if they got weaken or aged
pls rate me fixya if it helped
Posted on Mar 09, 2009
zohail
  • 1223 Answers
SOURCE: light on my samsung digtal camera charger is flashing orange and
pls checck the batt it is not taking the charge they are weaken and old pls ccheck it
pls rate me fixya for this if u like
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
Posted on Jul 02, 2009
BillB-SA
  • 2761 Answers
SOURCE: CAMERA WILL NOT CHARGE UP, I PLUG THE CHARGER IN
If you've recently changed the batteries, make sure that you have the right kind for your camera and that they're installed properly. That said, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. A "Very Helpful" would be greatly appreciated.
Posted on Nov 23, 2009
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
How would i know when my Samsung camerais through charging
you can know if the camera is charging by the indicator light in the usb cable, green light means it was full charged..red light means that unit still charging.
Jan 28, 2011 | Samsung L200 Digital Camera
Hi There, My ES55 digital camera is flashing orange when i plug it in to charge and doesn't turn on when off the charger. What does this mean? and what do i have to do to fix...
It sounds like the camera battery is not charging, take it to a camera shop to see if a replacement is required, they should be able to check the old one for you.
Jan 10, 2011 | Samsung Cameras
I have a digimax i6 pmp camera, when i try to charge it,the light on the charger turns red, then starts flashing orange and the camera will not switch on at all..can you help me?
sounds like you have a bad battery ... the charger has detected something wrong and shuts down with the error warning .. replacing the battery will likely resolve the problem ..
Oct 12, 2009 | Samsung Digimax i6 PMP Digital Camera
Nikon MH-53 Lithium Battery Charger - help?
download the manual here
http://www.retrevo.com/s/Nikon-MH-53-review-manual/id/605ag014/t/1-2/
Jul 30, 2009 | Cameras
Samsung nv3 camera not charging
Jun 29, 2009 | Samsung NV3 Digital Camera
L830 wont charge
it is possibly the battery itself. i have a two batteries for this camera one of them has this problem orange flashing light and doesn't charge and the other works fine. You might need to get a new battery. Good luck
Oct 11, 2008 | Samsung Digimax L830 Digital Camera
Camera not charging
i got the same problem...it means battery is somehow discharging instead of charging..better get an external charger and remove battery from camera after every use.
Aug 08, 2007 | Samsung NV10 Digital Camera
Samsung NV4 Digital Camera Logo
174 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
