Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
I have a Coleman Evcon GDAT070BDF that the fan is kicking on when the furnance and a/c is is turned off. Or after it runs on either it will kick right back on, sometimes instantly. I have already had thermostat changed and this is still happening
    Master:
    Sergeant:
  • 449 Answers
The problem is at the furnace have a pro come ouy to check it
Posted on Sep 10, 2010
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
When the furnace shuts down, blower kicks on and off
Probably residual heat kicking the fan limit control on and off. Readjust the settings on the fan limit control.
Nov 15, 2012 | Coleman Evcon Furnace Control Circuit...
I have a coleman evcon system model BRHQ0301BC. The fan on the outside unit will not always kick on. When the fan does not kick on the AC does work. Need a manual for unit and help repairing the proiblem.
I don't have a manual but you need to check the fan capacitor and the fan motor windings with a multimeter. If the capacitor looks swollen then it is probably bad. Replace it with one of the same rating.
Jun 07, 2010 | Coleman Heating & Cooling
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
My furnance is acting up you turn it on it clicks on then lights the flame gets big then seconds later the flames go out and the blower kicks on what could be the problem ive had several people look at it...
If the fan takes too long to come on, the high temp limit may be opening. Could be a defective limit, hard to say without more info. Another possibility is a mis-adjusted heat anticipator. A normal setting would be around .45 amp. The heat anticipator is inside the cover of the thermostat (older, analog style). Good luck.
Nov 28, 2009 | Tools & Hardware - Others
Fan in furnance
any furnace with a blower will go on your electric bill but it really should'nt draw enough power to raise your bill noticably unless it's running constantly.
Jan 24, 2009 | Coleman Propane Forced Air Heater...
I have a coleman/evcon heat pump. When the thermostat kicks on the contacts kick in and hum but the compressor nor the fan run. Is this probably my capacitor has gone bad?
I would check the hig voltage power supply to the unit. Check the main breaker and make sure it is on. Check the disconnect and make sure there is power at that point to the condensing unit. The contactor will kick in from the low voltage in the control circuit.
Jul 11, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
145 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
