Question about Electrical Supplies
I have two Zeus model 1200VA. The input is 220Vac 50Hz and the output is 220Vac 50Hz. The fuse is 6A/250Vac. It has a UK three pronged plug and the two outputs on the back are universal and can fit american made electronics. Everything I plug in makes a weird sound and pops then smokes and will not work again. What is happening? Oh and I use a UK to US adapter to plug in the UPS'
  • Richard Vieira Sep 09, 2010
    And they are Uninterruptable power supplies.
  • Richard Vieira Sep 10, 2010
    I have figured it out. The UPS itself has a switch built in that allows me to turn the voltage down to 120. Turns out actually reading the manual works, Haha.
  • 905 Answers
You state that you are using a UK / US adapter to plug in the UPS. Since the UPS is expecting 220vac, as nameplate states, it will also deliver 220vac on the output from battery power. The UPS may also have a universal power supply on the input so that batteries can charge at a lower voltage, and also allow the UPS to augment "dirty power" by using the batteries for extended service, rather than use the batteries alone.
From your description, the UPS is still making 220vac @ 50Hz, but the use of an adapter leads me to think that you are using devices that are intended for perhaps 120vac @ 60Hz. Wrong Voltage, Wrong Frequency.
Posted on Sep 10, 2010
  • Sheldon Dedek Sep 10, 2010
    Even though you are able to change the voltage to 120vac, you might still be looking at a frequency problem unless the switch changes that as well.
I need wiring diagram for Amana AKT3650E. I have 220VAC supply without a neutral. Electricain says the warning lights need 115VAC. How it that achieved?
So the manual:
http://media.datatail.com/docs/specs/164433_en.pdf
says the power requirements are 120/240 VAC 3 wire single phase.
Almost all wiring includes a ground wire, so saying 3 wire also says it additionally has a ground wire. However, many oven outlets were wired using the neutral as the ground (now considered illegal - especially for new installations) - so they had a 3 prong plug.
Metering from any 2 holes (at a time) in the receptacle should reveal 240 V (across the similar slots) and 120 V and 120 V (from outside slots to middle slot).
have a look at this thread
Installing 3 prong outlet for new range Family Handyman DIY Home Forum
Feb 24, 2015 | Amana Kitchen Ranges
I used to live in the USA where I bought a Sony KDL-46W5100 TV and was clearly told by Sony it would be fone to connect to SKY in the UK as long as I used thew HDMI input/output. However, it doesnt work!...
The TV should run on the 50hz. You will need the proper power cord as the prongs are different. The power supply should switch automatically but I would confirm this with Sony. I can't see anything in my information that says otherwise.
The North American power is 60hz and 110 volts while the Euro is 50hz and 240 volts. So you don;t want to force it too much or you could make expensive smoke ;-] With the proper cord you should just have to plug it in. If the video is fine with HDMI then you should be up and running.
Sep 16, 2011 | Sony KDL-46W5100 TV
There are three prongs for the dc input one on top two below that in a triangle pattern what are the voltages on these posts top lower left lower right
Isn't there a sticker on the back to tell you what voltage the unit runs? basically it depends on what country the unit is designed for, for example in the UK the voltage is 230V at 50Hz, while in the USA it is 110V. the socket you described is a standard IEC or "kettle" lead and can be used for many voltage types.
Apr 12, 2011 | Balance CM2017 17" Monitor
I have a Netgear wireless router WGR614 v5 with the AC adapter of 120V-60Hz-16W. I've moved to Europe where the electricity is 220V. Can I use an AC adapter of 220V for this wireless router? Thanks a lot...
Yes, make sure you have a new power supply with the right voltage output, enough current (if the new power supply is rated for more current output, it will be OK), and the right plug with the right polarity.
Check your power supply, some will actually work with a wide range of voltage, some actually go from 100-250VAC. 50Hz-60Hz
Jan 05, 2011 | NetGear WGR614 Wireless Router
Need to know color code for 220VAC receptacle, so can wire up an output cord. Had no cord with the generator. Have LRE 5500 portable generator. Have new 4 prong plug.
Hello Arthur,
For 220vac, you will have 2 blacks or Red and Black (line). The white is neutral, green / bare is your ground.
If you look closely at the plug, the contacts for the line will have either black screws, or be labeled as L1 and L2. Neutral will have a white or silver screw, may be labeled as N, and the ground will be green or silver, labeled as Ground, Gnd, E, or Earth.
Aug 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
MY COMPUTER JUST STOPEED AND I NEED 2 KNOW THE SPECIFACAITIONS ON THE POWER SUPPLY
If you are using latest system you need
Ac input : 220vac 3a 50hz
450watt minimum
Atx 2.03
Atx 12v
Dc output
+5v 28a -5v 0.6a
+12v 15a -12v 0.6a
+3.3v 16a +5vsb 2a
Apr 16, 2008 | Computers & Internet
Electrical Supplies Logo
106 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
