Question about Garden
What is the petrol oil mix ratio for a castor tr 22 cx grass strimmer
kel1guy2002
  • 3740 Answers
SOURCE: oil to gas ratio
Hi and welcome to FixYa, I am Kelly
It actually depends on the age of the unit. Anything within the last 5 years is 50 - 1. (Air quality standards!) Before that 40 - 1 and in the year 2000 it was 32 - 1.
Let me just say that running a unit with a 50 - 1 fuel mixture ratio leaves no room for error in the ability of the mixed oil to lubricate the engine and the engine piston will wear quicker than and engine with a higher ratio oil 32 -1. (Fact manufacturers don't want anyone to know!)
This on line calculator is great for computing mixtures with the exact quantities:
http://www.csgnetwork.com/oilfuelcalc.html
As far as what 2 cycle oil to use.... pick one. They ALL have to meet the same quality standards to even be called 2 cycle oil. Extensive testing has shown that no matter the mixture ratios form 32 - to 50 -1 they all eventually form carbon on the top of the piston. It was noted that carbon on the piston forms faster at 32 - 1 than it does at 50 - 1. (For what that is worth.)
Thanks for choosing FixYa,
Kelly
Posted on Apr 23, 2011
2strokeguy
  • 183 Answers
SOURCE: do I mix the gas
Your MightyLite trimmer requires a 50:1 fuel mix. Use a high quality 2 cycle oil that is made for lawn equipment. Do not use outboard boat oil...it will cause your trimmer to run too hot. If you use the mix that has fuel stabilizer in it, then the bottle will be 3.2 ounces. Use one 3.2 ounce per gallon of gasoline.
Posted on Aug 30, 2010
pippall
  • 1486 Answers
SOURCE: petrol oil ratio mix
25%to!%
Posted on Aug 09, 2009
  • 31 Answers
SOURCE: need to know petrol - oil ratio for mixing
Hi There, I'd recomend using Stihl Two Stroke Oil. Mix it at 50:1. Its the best stuff you can get. Never let me down yet, used in all my chainsaws and strimmers.
Rich
Posted on Aug 15, 2009
Testimonial: "Thanks Rich I will try 50:1."
kfishny
  • 5 Answers
SOURCE: ryobi PSC 3046y3e 30 cc petrol strimmer ratios of petrol to oil
WELL IF THERE IS NO 2 STROKE OIL TANK THEN YOU MIX IT WITH THE GAS. THIS IS HOW THE ENGINE GETRS ITS LUBRICATION AND WILL BLOW UP AND SEIAZE WITHOUT IT.MOST OF THESE SMALL ENGINS RUN AR 20 TO 1. OUTBAURDS RUN AT 50 TO 1. IF YOU PUT TO LITTLE ITS NO GOOD AS MENTIONED ABOVE. IF YOU [PUT TOO MUCH IT IS NT AS BAD AS IT WILL SMOKE A BIT AND POSSIBLE FOUL THE PLUG AFTER A WHILE. I WOULD GO WITH 230 TO ONE THAT WOULD BE 20 PARTS GAS TO 1 PART OIL 20GAL GAS TO 1 GAL OIL IS THE SAME AS 5 GAL OF GAS TO 1 QUART OIL OR 2 1/2 GAL GAS TO A PINT OIL OR 1 1/4 GAL GAS TO 1/2 PINT OILM GET THE PICTURE NOW. ITS DIVISION. AFTER A WHILE OF RUNNING IF IT SMKES AND THE PLUG FOULS JUST ADD A BIT MORE GAS TO YOUR MIX AND CLEAN THE PLUS WITH AN OLD TOOTH BRUSH AND I ALWAYS MARK MY GAS CAN WITH BLACK MARKER OIL/GAS MIX 20:1 OR WHATEVER.
REGARDS, PAUL
Posted on Sep 27, 2009
Is the JCB M25 strimmer petrol only or 2 stroke please. can't find manual. Many thanks, Margaret
it is a petrol engine and the carby listed indicates that it is a 2 stroke
the oil /fuel mix ratio is 50:1 with a fuel octane rating of 91 ( do not use e-mix fuels ) recommended oil from the manufacturer specifications is a synthetic 2 stroke oil
Brand of manufactured oil optional
Jul 30, 2017 | Garden
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
What is the fuel/oil ratio for a spear Jackson spjht26 hedgetrimmer
40:1 ratio is the norm, up to 50:1, you can get a 40:1 ratio mix by adding 2.5 cc of 2 stroke oil to 1 litre of petrol. Make sure you do not use car engine oil, it must be special 2 stroke oil which is what they sell for old lawn mowers and strimmers etc. If your exhuast is smoking then you put in too much oil so add more petrol...
Jul 10, 2014 | Garden
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
What is the petrol/oil mixture ratio for a STIHL FS 36 R Grass Strimmer?
Hi, 50 to 1 with stihl oil or 25 to 1 with any other brand 2 cycle oil. Hope this helps, regards Phil.
May 30, 2011 | Garden
Oil to petrol ratio?Thanks Partner B300BX strimmer
If you are using stihl oil then the mix is 50:1
Jul 31, 2010 | Husqvarna Garden
Need to know petrol - oil ratio for mixing 2-stroke fuel for Electrolux-Partner B300B garden strimmer. The manual gives every kind of technical and other info the user is never likely to need; except this...
Rich
Aug 15, 2009 | Garden
Do I just fill up my petrol strimmer with petrol, or do I have to put in some two stroke oil as well?
yes 2 stroke in weedeaters, trimmers, etc, look on the cap, or sticker and see the gas/oil mix ratio
Jun 07, 2009 | Garden
2 stroke mixture ratio for strimmer
The basic fuel/oil mix is 50 to 1
May 04, 2009 | Garden
Garden Logo
308 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
