Question about Vacuums
I have a sunbeam drinking water cooler - Item #0282 and the cold water buttom is stuck?
Sunbeam steam mop is not heating the water
Call Sunbeam Customer Support .... 1-866-726-1150
Regards,
Dennis
Aug 30, 2014 | Vacuums
Hi, I have a older model Sunbeam water cooler that hasn't been used for a while ..Need to know how to clean and sanitize it? got any ideas
Vinegar might help. Run a bunch through the water cooler and it can help clean out the unit (and will give you some disinfection as well) without damaging it. I have used vinegar in my coffee pots with much success over the years. Once you are done, you will want to run a LOT of water through it to get the vinegar taste out of the system, though. If you are not a fan of the idea of vinegar in your water cooler, you can try coffee-pot cleaner ... it is more expensive, but is designed for the same basic use.
Jun 07, 2011 | Vacuums
Prima water cooler just noticed that the cold water is not cold. Looked in back and copper coils all iced up.. turned off and put cut to collect water, what needs to be replaced> have another...
try to adjust to lessen the setting of thermostat maybe the setting is to full thats why the thermostat cannot cut off after the water chilled. then observe the unit.
Mar 02, 2011 | Vacuums
I own a watercooler 4 yrs old model # whkmd30The bottle water get extremely hot. There is good ventilation Any suggestions
Your water cooler has a Hot water section, also-- correct?-- You have 2 faucets, right?-- One COLD and ONE hot!
Is it possible that the section that does the HEATING, is stuck ON and is in some way heating the water back up thru the connection, into the big bottle?
Another possible thought: Is there a heater to prevent freezing of the bottle?-- Maybe it is stuck ON
Note: Your question ended up under Vacuums-- We are just trying to help-- Feel free to re-list your problem up there where water coolers are-- OK?
Sorry we couldn't be more helpful here in the Vacuum cleaner area-- :-)
Mack B
Jan 29, 2011 | Vacuums
Hi I have a new sunbeam Eskimo ice maker I have had it on now for 3 hrs approx the water is cold and i have it on the med size blocks its only bringing down 4 ice blocks in the 3 hr period is that normal...
Sorry to read about your problem, I hope this helps you out.
yes
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Sunbeam Vacuums
I need a replacement cap for the water tank Sunbeam humidifier model swm5251
Official instruction from this device suggests to call Sunbeam consumer service at 1-888-264-9669 to order replacement accessories.
Nov 28, 2010 | Sunbeam Vacuums
Vacuums Logo
80 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
